Farmall M whats the max compression
IRISH RED
11-09-2003 07:38:40
Building an M with 4 3/8 bore and 7.5 stroke with good parts but how much compression is too much whats the max cyl psi a person schould run ? thinking of 11 to 1 but not sure
Thanks for the help
ChadS
11-09-2003 09:11:16
 Re: Farmall M whats the max compression in reply to IRISH RED, 11-09-2003 07:38:40
I would estimate an engine like that would be around 250 to 280lbs compression. You should be able to keep a head gasket sealed with that high of compression. NOTE,, Make sure that you check the block deck to make sure it is true. The slightest distortion will cause gasket failure at that kind of compression. 300psi is about the max I would recommend for an engine with out having to o ring the block, Just my opinion,, ChadS
one of...
11-09-2003 09:32:36
 Re: Re: Farmall M whats the max compression in reply to ChadS, 11-09-2003 09:11:16
one of the top M's in the country is running 360+ psi in his M. It's well up in the 500's on cubes too. He puts rod bearings in it a lot :-)
FULLPULLER#1
11-09-2003 20:04:55
 Re: Re: Re: Farmall M whats the max compression in reply to one of..., 11-09-2003 09:32:36
It must be a Lemmons motor,them things eat bearings,,,the only way to know what your comp. is ,,is to C-C the head..... .....
11-10-2003 15:17:27
 Re: Re: Re: Re: Farmall M whats the max compressio in reply to FULLPULLER#1, 11-09-2003 20:04:55
not a lemmons but the idea and design behind it are the same.
a puller
11-10-2003 12:58:06
where do you get a compression tester that goes above 300psi???
