5020/6030 out there ?
5020Chris
11-10-2003 09:40:20
Does anyone know any 5020/6030 used for pullin and farm work ? do they do any good?
Thanks.
856puller
11-12-2003 14:52:37
 Re: 5020/6030 out there ? in reply to 5020Chris, 11-10-2003 09:40:20
some friends of mine pull a 6030 in 1300 open farm they run in 8th its quite a show!!
BigArt
11-11-2003 14:32:07
G-man's right, the issue is easy hp versus dealing with the weight of the unit---hard to haul, and even though a pulling only unit can get easily under 9000lbs----that is labor intensive and leaves farming out. Another positive, is the trans and rear are durable, as is the engine with moderate rpm restraint. e-bay has gobs of manuals, tech books and owners manuals, as well as a 5020 or 6030 for sale occassionally. To locate one quickly, fastline.com will fill the bill. Good Luck.
G-MAN
11-11-2003 10:52:23
I've got a friend that had three 6030s he farmed with, out in wheat country. He sold one, but I believe he still has the other two. They're very strong and reliable tractors. There are also some guys that pull a 6030 down home in farm pulls. Come time for the heavy classes (15,500, 18,000 etc), they always go back and forth with a 4640 quad-range that some friends of mine pull. 6030s only came with synchro-range trannies, so that's somewhat of a disadvantage, but if they can get it moving, it pulls like a freight train. I've seen it with the front wheels 4-5 feet off the ground at the end of the track. They came with naturally-aspirated or turboed/aftercooled 6531 engines (531 cubes), but a 6619 (619 cubes) is a simple swap, and you can make pretty good horsepower with one of those just by turning the screw. I've seen a 6619 in a 5830 forage-harvester make 400+ horsepower, just from the pump being turned up. We "detuned" it to 325.
mike
11-12-2003 06:19:22
 Re: Re: 5020/6030 out there ? in reply to G-MAN, 11-11-2003 10:52:23
not being smart but how do they check hp on forage harvester, and what is the difference in that engine viurs tractor? thanks mike
G-MAN
11-12-2003 07:43:48
 Re: Re: Re: 5020/6030 out there ? in reply to mike, 11-12-2003 06:19:22
There is an adapter shaft that bolts onto the hub of the large fan that blows the silage into the wagon. That fan is direct-driven off the back of the engine clutch, through a right-angle gear-set, so it's a fairly accurate place to measure horsepower, with the only loss coming from that gear-set. It's a regular 1000 rpm shaft, and you roll the dyno right up to the side of the forage harvester. I don't know what all the differences would be compared to a tractor, although the accessory mounting and so forth might be different. The point was that with the right fuel system, a stock 6619 can make some righteous power.
BigArt
11-12-2003 13:39:33
 Re: Re: Re: Re: 5020/6030 out there ? in reply to G-MAN, 11-12-2003 07:43:48
Dave Snyder, of the twin turbine "Legend" fame, being Art Arfons old tractor---has a massive cube 6030---somewhere between 896 and 902 cubes---per Turbine Guru Don Deane---rpm range was "come out about a 1000 and cross the finish line about 2100---" a buddy of mine has a video of it---a true "freight train" of a puller!!! BigArt
