Farmall H front wheels?
FarmallOne
11-11-2003 14:32:36
Hey I was just wondering where I could get hubs to put 5 or 6 bolt wheels on my H I have seen them for a M but didn't know if they would work any help would be appreciated
Ohio H
11-13-2003 13:57:02
 Re: Farmall H front wheels? in reply to FarmallOne, 11-11-2003 14:32:36
I have 300 utility hubs with 15x4.00 firestones on very light kubota six bolt rims on my H. bolt on swap, same bearings.
FB
11-12-2003 13:13:38
If you want to lighten it up i would just cut off the whole wheel hub spindle....etc all the way down just to the pedestal and get some spindles and hubs from Jegs or an or somewhere and weld them on...you could put about and car wheel or drag racing wheel you want
Paul
11-12-2003 06:17:12
I notice the pictures of 350 Utility Tractors with 6-bolt hubs. Would they fit on an "H"??
ChadS
11-12-2003 09:36:13
 Re: Re: Farmall H front wheels? in reply to Paul, 11-12-2003 06:17:12
MM Z hubs fit it too,, ChadS
Jim
11-11-2003 16:14:03
One individual I know used a 460 or 560 tricycle front so he had the pressed steel wheels. Not sure it lightened the tractor all that much. Hope others will post on this topic.
ChadS
11-11-2003 17:48:40
 Re: Re: Farmall H front wheels? in reply to Jim , 11-11-2003 16:14:03
I had found that the old McCormick wagon gears had the same spindle as the H, had 6 bolt pressed steel. Hope this helps,,, ChadS
farmall man
11-11-2003 19:04:51
 Re: Re: Re: Farmall H front wheels? in reply to ChadS, 11-11-2003 17:48:40
i think the M front end should fit on it becuase i have one of each, i can measure them and get back to you but if they dont line up it would just be a matter of drilling a couple new holes for the front end to go on.
IH H Puller
11-13-2003 09:30:03
 Re: Re: Re: Re: Farmall H front wheels? in reply to farmall man, 11-11-2003 19:04:51
The M is too big
