JD G REAR END HOUSING CONVERSION
G VIRGIN
09-24-2001 19:32:40
I AM BUILDING MY FIRST G FOR PULLING. CURRENTLY RUNNING A FAIRLY STRONG B. MY '51 G HAS THE F874R POWER LIFT REAR END COVER WITH THE POWER-TROL VALVE HOUSING. TOO MUCH WEIGHT! WOULD LIKE TO REPLACE IT WITH THE 'BARE-BACK' COVER, F951R, NO LIFT, NO HYDRAULICS. IS THIS AN EASY CONVERSION? WHICH PTO SHAFT DO I NEED? DO I NEED TO CHANGE ANY GEARING? ANY OTHER HELPFUL TIPS NOT PERTAINING TO THE ENGINE ARE GREATLY APPRECIATED.
M Bisbee
10-05-2001 16:56:02
 Re: JD G REAR END HOUSING CONVERSION in reply to G VIRGIN, 09-24-2001 19:32:40
K&K Antique has plain back covers reproduced in aluminium and their 1/10th the price of real ones.You would have to do some machine work to run the PTO. Hope this helps.
scott JD G
03-13-2005 16:08:17
 Re: Re: JD G REAR END HOUSING CONVERSION in reply to M Bisbee, 10-05-2001 16:56:02
Do you have any info on the rear housing covers that you could send me?
Gman
09-24-2001 20:33:31
G Virgin have you got a Styled G Flat back????? Obtaining the flat back might be your only problem their not only expensive but scares as hens teeth. Gman
