G conversion
JDTRUBLE
11-14-2003 16:28:45
I am looking to replace the block on my unstyled G with a block off of a styled G,put in aluminum pistons,install bearing type rods, and bore it .125. has anyone done this before or has any recomendations for a project like this.(need more power)
JDGnut
11-14-2003 20:00:05
 Re: G conversion in reply to JDTRUBLE, 11-14-2003 16:28:45
I have seen lots of US G like this.. I have never gone this way.. I have put the US block is styled G's.. You will be gaining compression.. If you were stroking it.. I would stick with the US block... Not much to change... cut down the push rods.. bend the oil line to the rocker cover.. shorten the linkage to the carb.. install a spacer for the air inlet.. or install your filter.. and add your flavor of High octane fuel.. Good luck
JDGnut
jdtruble
11-15-2003 16:26:40
 Re: Re: G conversion in reply to JDGnut, 11-14-2003 20:00:05
the person that I had called about the aluminum pistons said that I would have about 11.3 to 1 compresion, that would be with the bore .125 over.How much would stroking it help(I still want to pull in the "stock" class).what recomendations are there to get more power out of a very stock unstyled G (I have PUT ON A manifold from roberts carborater). any sugestions would be nice before I start the project.
