Decking an H block
Nate
11-17-2003 15:33:00
Does anyone have an input on how much material can be cut from an H block? I assume the top of the block is rather thick. Can it be cut down to the sleeve counterbore? Thanks to all.
ChadS
11-17-2003 15:35:08
 Re: Decking an H block in reply to Nate, 11-17-2003 15:33:00
No,, It makes it weak. It will crack,,, you could take about .050 off of it and be safe. the deck is only .250 thick if that much. and the head studs will pull a weak spot in a hurry. ChadS
