4500# Super M or MTA
baystate binder
10-01-2001 13:07:42
How does one go about lightening up one of these tractors for the 4500 pound class. Is it a great big problem to lighten them up or not too difficult.
Bryon
10-09-2001 08:55:25
 Re: 4500# Super M or MTA in reply to baystate binder, 10-01-2001 13:07:42
It shouldn't be to hard. We can get our M's in 4500 pretty easy, an SM wouldn't be much different. Switch to steel rims, cut the deck off, built a front end. The SMTA might be another story. One of the guys around here used to run a SMTA. He built a deck and front end, but I don't think he could get into 4500. They swapped their rear end and TA for a straight rear end. Their SM will pull 4500 with the cast deck, I think.
TP from Central PA
10-04-2001 18:00:15
I believe you could get a SM down to 4500 stripping everything off not needed and adding extras like an alluminum radiator.
I got one question for ya, how would you get a SM-TA down to 5000 let alone 4500, I pull a field fresh SM-TA and I tip right in at 6500. 4500 might be possible if you want to take the torque and the PTO out, but why bother when you can just buy a SM.
baystate binder
10-05-2001 05:21:54
 Re: Re: 4500# Super M or MTA in reply to TP from Central PA, 10-04-2001 18:00:15
We pull 2 super mta with nothing taken off and they weigh 5900#s I don't know why yours weighs so much.
TP from Central PA
10-05-2001 17:29:58
 Re: Re: Re: 4500# Super M or MTA in reply to baystate binder, 10-05-2001 05:21:54
I am going to a pull tomorrow, I have to check the scales to see if their accurate. I tipped in right at 6500 last pull!
I WISH I could get down to 5900, I bet you have all your wheel wieghts off, I leave two pairs on each wheel as it is a farm tractor, not a puller. I never felt like taking them off for a couple of pulls just to need to put them back on when I have to head to the fields.
Do your SM-TA's pull well? I pull off the stock drawbar and still beat some of my friends with souped-up M's and SM's- Plus, they run first gear, I go for none other than 2nd!
baystate binder
10-06-2001 14:27:29
 Re: Re: Re: Re: 4500# Super M or MTA in reply to TP from Central PA, 10-05-2001 17:29:58
the answer is yes they pull very well. You are right there are no wheel weights on the tractor. If you take your wheel weights off then run 4 pieces of threaded rod or long bolts you can stack the two weights on each side and remove them very easlily. It is a pain to be switching weights on and off all the time especially with the factory method. We always pull in second gear you will just spin out in first.
