Farmall: Is it possible??
HMMMM
11-26-2003 07:08:24
How would an M with only an LP manifold and Intake and a bored carb PULL in the 8000 lb class. An M is 248 ,that ad didn't say it was bored or anything, how would that pull in the 8000 lb class, we have two M's one with 264 has trouble in the 6600 class and one with 281 that ALMOST ALWAYS dies in the 8500lb class, And the tractor for sale is RUNNING CUTS..... ..... ..HOW IN THE WORLD....he is either pulling our leg or runs EXTREMELY bad tracks ( or has a secret i don't know about??)
bob luvin the M's
11-28-2003 17:07:10
 Re: Farmall: Is it possible?? in reply to HMMMM, 11-26-2003 07:08:24
well muy daddi had him a good un and his good nieghbors freind and his entelectracy(aww hail however ya spell that fancy werds)which reminds me muy pa didnt let us go tu skool. newuys they new a good man who knew a man that was related to a man that had one uf them thar tracters and said he pooled that thang n frst gear in 9000 pound class once. and spun his tores so fast that them thar cows cumed home twice i tell ya wat.
BUD BARENIE
11-28-2003 15:06:01
6000LB CAN PUT A BAD HURT ON 4-1/8 X 5.25 ANYDAY
I AGREE
Jeff
11-27-2003 20:01:32
I have seen one around here (West Tn West Ky) that does pretty good up to about 7500 although a couple of JD G's usually beats him. As far as I know he has the LP head and biggger carb and about all. Of course this is pulling in first gear which it seems alot of folks on here don't do as they seem to all be into the bigger classes. We usually pull the Track farmer sled around here if that helps any.
Adam
11-26-2003 19:40:45
It just says it pulls 8000lb. It doesn't say how far it makes it.
Flogger
11-26-2003 15:50:23
Would probably depend a whole lot on the tire size and the track. A good track can put a hurtin on an M in 6000.
Jack
11-26-2003 09:41:53
I want to see it pull in 8000 lb on a good clay track.I have seen stroked M's moan in 7500.
lots of variables
11-27-2003 16:09:04
 Re: Re: Farmall: Is it possible?? in reply to Jack, 11-26-2003 09:41:53
it has tons to do with the sled and track. a stock M would be lucky to make it a 100 ft. around here in the 5000 lb. class, much less 8,000.
