273 Buda mods
TGW
03-25-2001 15:39:40
Besides the crankshaft is there any other parts out of a 262 allis that would help for power(cam, head,ect.)?
Justin
03-25-2001 16:58:39
 Re: 273 Buda mods in reply to TGW, 03-25-2001 15:39:40
Unless you are going to grind your cam for clearance when you install the 262 crank, you will have to use the 262 crank. It is already knotched for clearance of the extra stroke. The 262's cam is set up for the slightly higher RPMs that the 262 turned, but will still work fine for your motor and give you plenty of low end grunt. Also the entire 262 motor will bolt up with minor modifications.
Justin
Justin
03-25-2001 19:00:02
 Re: Re: 273 Buda mods in reply to Justin, 03-25-2001 16:58:39
I meant to say unless you grind your stock cam for clearance, you'll have to use the 262 cam, not crank.
