Farmall spark-plug gap
Nile Brown
11-29-2003 19:17:51
I am pulling a SM farmall with an electronic ignition. I was told I should gap the plugs 10 thds more than the normal setting. I am using 8116 autolites. What is your opinion?
TimC
12-02-2003 18:37:50
 Re: Farmall spark-plug gap in reply to Nile Brown, 11-29-2003 19:17:51
Really high compression engines need less gap to insure it makes it across the gap. If you are using an MSD or equiv you can take it out futher.
Farmall Daddy
11-29-2003 20:34:07
On my M I usually set them at 50-55 thousandths. I run the stock distibutor though, so I don't know what advantages, or disadvantages there are other than you don't have to change points. Hope this helps!!
Dave
11-29-2003 20:13:51
I have a IH400 with electronic ignition and am using a .045 gap..... seems to throw a huge spark. I ran all year that way.
