Farmall H-and 460 engine swap
ChadS
12-01-2003 10:56:30
Hello!! Got some questions for all of ya. Please , no bashing ok? Just want to do something wild HA HA. Here is my plans,, I have a 50 H frame,, and rear end. and a rebuilt 263, 6 cyl engine from a IH 403 combine. I was staring at the both, engine, and the H,, and I think I could put that 6 cyl in that H. Here is where my mind has some questions though.. Some have said that the early 460 tractors were nothing more than H-350 rear ends.. Is this true? Is the 350 and the 460 bellhousing close to being the same? I am not worried about the TA,, in this case, I want to use the H bellhousing. But,, Would the flywheel fit inside the H bell housing? I would not be afraid to build a steel flywheel either. but would still like to use the H starter on it,, I measured the back of the blocks,, both the H, and the 263,, I can build a plate to match up the 6 cyl and the H bellhousing,, and still have room to bolt on the frame rails. How many bolts hold the flywheel to the crank on the 6 cyl? Now,, like I said,, no bashing,, just a country boy who wants a new toy ha ha. Need some help,, any specs that anyone would be nice enough to share,,, I would be very appreciative. Thanks,, ChadS
Puller504
12-02-2003 03:16:17
 Re: Farmall H-and 460 engine swap in reply to ChadS, 12-01-2003 10:56:30
Hi ChadS! hey, nobody caught it yet but the 403 combine motor at 263 cu. in. isn't the same as a Farmall 460. My 460 has 221 cu. in. I think your 263 is a Farmall 560 engine, same bore as the 221 but with a longer stroke crankshaft. A worked over 263 would be a cool deal to bolt into a "stock" 460 for the track next season! My Dad's Farmall 656 gas also had a 263 engine. It was a fine tractor. Don
ChadS
12-02-2003 05:15:53
 Re: Re: Farmall H-and 460 engine swap in reply to Puller504 , 12-02-2003 03:16:17
Yep,, you are correct!! It is a 263. I had found out some info,, the clutch is the same as the 350-early460, so I 1 more thing going for me!! HA HA ChadS
Buzzman72
12-02-2003 06:36:48
 Re: Re: Re: Farmall H-and 460 engine swap in reply to ChadS, 12-02-2003 05:15:53
Now Chad, let me add my 2 cents' worth...I'm coming over here to YT and the pullin' board after dealing for years with old International trucks...and you know that just about every 6-cylinder tractor motor IH used in the '50's and '60's had a truck equivalent...so if you run into problems with the C263, remember that the BD264 truck motor is about the same...and there was always the BD282 and BD308 truck motors, so with a little parts swappin' ingenuity, you might just get a head/valve/piston combo to make your 460H "Somethin' EVEN Wilder YET!"
Good luck!
To find out about these old Binder truck motors, check out the link below:
AirtimeWC
12-01-2003 18:50:10
Chads, I have a friend who put a RD 450 truck motor in an H or 460 rear. Will be fast.
ChadS
12-02-2003 06:28:48
 Re: Re: Farmall H-and 460 engine swap in reply to AirtimeWC, 12-01-2003 18:50:10
I heard that could be done too!! Yeah it will be a monster!! If it would run like Huttons, W-40,, look out!!! Gonna be a speedster!! ChadS
Flogger
12-01-2003 13:55:55
Hey Chad,
Don't know about Indiana, but that would probably be a felony in South Carolina lol. If you must have a 6 banger a DT407 or 466 would have a little more zip I expect. Might be able to run 5th gear in 3500 with a properly tweaked 466.
Good luck and keep us posted!
strokin'301
12-01-2003 19:35:10
 Re: Re: Farmall H-and 460 engine swap in reply to Flogger, 12-01-2003 13:55:55
Apparently you have never heard of any 500+ ci. c301 engines....5th gear no problem..
ChadS
12-02-2003 05:19:56
 Re: Re: Re: Farmall H-and 460 engine swap in reply to strokin'301, 12-01-2003 19:35:10
No,, I have never heard of one that big,, But maybe in a year or two,, if it seems to hold together, a big motor will be right in line,, Thanks,, ChadS
Flogger
12-01-2003 20:06:57
I don't doubt a bit. 12 MPH is about as fast as they'll let em go around here so I doubt if they could make it in 5th gear.
Figured I'd hooraw old Chad a little. I think these NATPA folks have his dander up. I still think he needs to bring "Something Wilder" down here to NC for a little heads up match with the WILDMAN'S H.
How bout it Chad and WILDMAN?
Chads
12-02-2003 05:18:29
 Re: Re: Re: Re: Farmall H-and 460 engine swap in reply to Flogger, 12-01-2003 20:06:57
Yep, HA HA, Can't afford to buy a 460 tractor,, so why not make one!! My plans is to make that 263 stong enoughto run 4th gear solidly, and run about 3000rpm,, should be right around 12mph,, with 14.9X 38s. ChadS
ChadS
12-01-2003 15:37:50
HA HA,, maybe just as illegal!!! HA HA,, I think a 407 or a 466 would be a little too big for me .. ChadS
BUD BARENIE
12-05-2003 07:08:09
 Re: Re: Re: Farmall H-and 460 engine swap in reply to ChadS, 12-01-2003 15:37:50
HEY CHAD (DCTOM) SCARES THE $ELL OUT OF ME, THE GUY GOT TO MANT IDEA'S !!!! HE AIN'T TRACTOR PULLIN HE'S CREATING ALL KIND'S OF STUFF !!!
NO WONDER WHY HE PULL'S SO WELL !!!! I GOT TO PUT MY OZZZZZ THINKING CAP ON !!!!!
MAN DO I GOTTA CATCH UP
HAHAHAHAHA
dctom
12-01-2003 12:22:11
you may have to drill the back of engine to fit the H bell houseing, again that is what i did for the 201 in the VAC. tom
dctom
12-01-2003 12:20:20
chads: why not machine the H flywheel to fit the 460 crank? that is what i did to put a 201 combine engine in a VAC that way the H starter would work no problem just a thought from a case friend tom
ChadS
12-01-2003 12:59:00
 Re: Re: Farmall H-and 460 engine swap in reply to dctom, 12-01-2003 12:20:20
Though about doing that too, I will find out about the bolt pattern on the crank,, if it is a 4 bolt,, it may bolt right on, hoefully,,, LOL. The top bolt holes will have to be drilled and tapped,, I have not looked at that part yet, Thanks Tom!!! How have you been? ChadS
supermpuller4
12-01-2003 14:16:40
 Re: Re: Re: Farmall H-and 460 engine swap in reply to ChadS, 12-01-2003 12:59:00
I've seen a IH combine motor in a 300 so a H shouldn't be a problem. The frame was longer but I didn't look at it very close, sounds like a good puller in the works.
turbo 560
12-01-2003 14:26:27
 Re: Re: Re: Re: Farmall H-and 460 engine swap in reply to supermpuller4, 12-01-2003 14:16:40
The 6cylinder flywheel has 6 bolts
ol george
12-01-2003 17:40:35
 Re: Re: Re: Re: Re: Farmall H-and 460 engine swap in reply to turbo 560, 12-01-2003 14:26:27
should not be a big problem, friend put a 706 in an M and some others have put a 466 in a 560 so I would think you wouldn't stress too much over this conversion.
