An A carb is better than a G '51 ?????
Ryan Teah
10-04-2001 11:09:41
I have heard that am "A" carb is better on a "G" than the '51 that I am running. I puller at a local pull is running one on his beefed up G! And he is running a fuel pump! Are some of us that are running a 1951 carb...missing that boat????
Ryan
Gman
10-05-2001 17:08:50
 Re: An A carb is better than a G '51 ????? in reply to Ryan Teah, 10-04-2001 11:09:41
Ryan a Dltx-71 is a A gas carb and a decent replacement for a 51,I've neve took a mic and measured the throat to see if they are the same.Apuller needs all the air it can get.The venturi is pobably smaller. Look on the boss oposite the choke you will see the # of carb stamped in it,even a 51 has to honed out to get max. flow. Thre's a couple of guys here on the board that probably know the difference in ventrui of the two carbs,I'll stick with the 51 bored out,if I can be of any assistance post back. I beleive you are a young tractor man so hang in there thats the way you learn. Later Gman
