4020 puller needs more
tim
10-05-2001 19:49:49
pulling jd 4020 diesel in farm classes looking for more power. i have some pump work done and
the injectors a 4430 cam and engine balanced runs
in the 4000 rpms ,i do pretty good at the pulls but want to get more horse power. any suggetions
with this engine. remember i can not run a turbo in these classes. is there any different equipment out there like injection pumps, injectors, or maybe a different head. talk to me men i want to know all the secrets out there
Get something RED instead of a gutless deere
10-29-2001 09:21:54
 Re: 4020 puller needs more in reply to tim, 10-05-2001 19:49:49
nothing runs like a Deere when scared from an IH
G Taylor .exhaust
10-09-2001 13:45:44
What kind of exhaust manifold is the tractor running?
tim
10-10-2001 05:24:31
 Re: Re: 4020 puller needs more in reply to G Taylor .exhaust, 10-09-2001 13:45:44
Iam running the standard cast manifold
G Taylor
10-10-2001 11:29:56
 Re: Re: Re: 4020 puller needs more in reply to tim, 10-10-2001 05:24:31
Tubular steel headers will reduce backpressure & maybe even help scavenge if tuned correctly.
Wags
10-09-2001 10:29:29
I am going to tell you a few things that will help you out. If there are no rules about running propane injection into the intake manifold and put you an electric switch on it and a regulater if you wanna know more about it e-mail me some other things you can do is run you rossa master 45 head and take it to columbus diesel in columbus ohio and get it lazered out to 540 then put you a 4240 cam instead of that 4430 cam then get your head ported and polished and flowed that should make her run pretty good.
thetractorguy
10-07-2001 09:35:18
tim, give doug roberts a call at roberts machine in carthage mo he is the premier jd puller he can make your jd run
G Taylor
10-07-2001 07:54:57
Extrude Hone is much cheaper than they used to be. They can flow more out of the head/intake/exhaust then any person can with a grinder.
Al
10-06-2001 20:31:04
Don't spread it around but the secret is more cubic inches, more rpm or both. Make sure you find a head that will flow enough. You can probably make more power with gas than diesel in a naturally asperated class. Like I said keep these secrets under your hat.
Dave N
10-06-2001 19:32:47
With a naturally asperated engine you can only go so far with pump and injector mods. I would work on the head get it to flow more air larger valves porting ect. Also work on your intake to make it flow more. a flow bench would be nice to see if you are making inprovments.
JDJIM
10-06-2001 21:00:42
 Re: Re: 4020 puller needs more in reply to Dave N, 10-06-2001 19:32:47
I just thought of this when flow bench was mentioned there is a tractor performance shop near Freeport Il. has a flow bench and a lot of other goodies , guys name is Mark Colberg maybe you've heard of him he pulls a G1000 called PROPANE I've known him for a long time but everything he says to do is over my budget , guess I'm to cheap . He knows a lot about all colors even makes heads for the!!!!! those!!!!! ! RED ones !!! JIM
Ryan Teach
10-06-2001 16:05:04
Dear Fellow Puller,
I am running into this same problem! I pull a 1951 G John Deere, and want to move up a class. We have a bunch of Olivers that run 88's. The have found out that an Oliver 1850 block will bolt right into a 88. Isnt that amazing, it would be nice if a 4010 block would bolt into my G :-)!! I tell ya, there hard to beat! I have dont so 3 times with my G. But, I want to run a 4010 against them....and show them the "true shade of green".
Please e-mail more anything that you find out!
I have heard of this company that used to advertise in the back of the hook. There title was "8th gear proven quality" I did not save the article, and I am kicking myself for not doing it. 8th gear, can you imagine that! In a farm class! WICKED!
Thanks for what info you might give me, Ryan Teach Gays Mills, WI
Al
10-07-2001 04:52:29
 Re: Re: 4020 puller needs more in reply to Ryan Teach, 10-06-2001 16:05:04
Wait til you find out what the Moline crowd is doing! You'll love it. Pull out a 400+ cubic inch engine and bolt in an engine that strats at 800 cubes and goes up from there. ;-)
Al
