Farmall Head
colekicker
12-07-2003 22:08:53
Ok, I have read a lot of the posts over the LP heads. Is the M and SM the same LP head? Is the main difference the size of the combustion chamber? Between the LP manifold and the gas manifold, how can I tell which is which? For pressed steel wheels, who is manufacturing them. I am wanting to run a 15.5-38s. Also, with the governor, I have a couple governors, but what kind of changes do I need to make inside? Thanks for the help.
BUD BARENIE
12-11-2003 15:04:03
 Re: Farmall Head in reply to colekicker, 12-07-2003 22:08:53
THERE WAS NEVER AN (M) PROPANE HEAD, DIDN'T COME OUT UNTIL S-M. THE PROPANE HEAD WILL FIT ON AN (M). THE COMBUSTION CHAMBER IS ALOT SMALLER. IF YOU DON'T HAVE ONE THEN SPEND 2000.00 AND BUY ONE! WHAT IS YOUR CASTING NUMBER ON YOUR HEAD ?
GOVENOR- STOCK GOVENOR IS FINE BUT CHANGE THE SPRING !!!! PROPANE MANIFOLD BREATHES WELL !!!!
COMPRESSION RATIO IS EXTREMELY IMPORTANT, GET TO THE MACHINE SHOP AND ASK HOW TO FIGURE IT OUT !!!
KEEP READING, AND POSTING. I HAVE A STOCK SUPER-M
AND A 400 GAS HEAD DOES REALLY WELL
PAY ATTENTION TO DETAIL
