Shaveing the head on 70 Oliver
Ken
10-08-2001 19:50:32
How much can you cut off a 70 Rc head and how much compression change can I get per, 1/8 " Ken
Ted
10-08-2001 20:40:01
 Re: Shaveing the head on 70 Oliver in reply to Ken , 10-08-2001 19:50:32
Ken,You can definetly help shrink the 70's huge stock chambers by milling.I gained the most compression from bore & stock changes but was still able to cut the head down without running into excessive numbers (thinner head gasket makes quite a difference also).I would recommend using the pushrod cover,water pump bolt,and rocker geometry changes etc as your guide as to how much to cut.I think you'll find the numbers are pretty decent without getting into lots of extra work "fixing" problems you made in trying to get a 75cc chamber
