AC WD-45 Puller
PNW Puller
10-11-2001 16:56:29
I would like to know if a WD-45 will work in the farm stock pulling class? Will first gear pulling work OK with 14.9 X 28 rears? What weight classes would it fit into? I am just getting started in the WA state area.
John
10-13-2001 06:28:25
 Re: AC WD-45 Puller in reply to PNW Puller, 10-11-2001 16:56:29
I am not sure the weight on a 45 but the ones I see pull go in a 4000# 4500# class I beleive its because first gear is high but most of them are running 12/6--38 tires they do very good..sorry I couldn't help more...
Randy Hanshew
10-20-2001 01:10:01
 Re: Re: AC WD-45 Puller in reply to John, 10-13-2001 06:28:25
That WD45 is a good pulling tractor. Leave the 28
inch rims on it. If taller tires are put on it will gear it up and you may have problems powering
out when pulling the sled. The allis CA is another
real good pulling tractor in it's class. I pull
old Farmalls but the older Allis really shines in
their classes.
