G CAM GRIND?
G thing
12-21-2003 18:00:54
Any one running a roberts pulling grind cam in a stock stroke G? I am running stock stroke ,.125 over high comp. pistons with flat head BIG intake valves manifold and carb opened up match ported and polished . Tractor runs really strong but just does not lug down and carry like it should at the end.Will his cam help me out,or is the grind to much with out a stroke? I STILL HAVE STOCK CAM IN THE TRACTOR.
Gthing
12-24-2003 05:29:18
 Re: G CAM GRIND? in reply to G thing, 12-21-2003 18:00:54
Thanks for all the in put. I am running 16.9x38 tires. I think i will try the cam.
tractorboy
12-23-2003 18:13:43
I talked to several engine builders about designing an engine for an A and they told me that the best cam you could get was a 630 cam. Maybe this would be same for G. I put 60 cam in early A once and it really done a good job.
buickanddeere
12-23-2003 21:38:49
 Re: Re: G CAM GRIND? in reply to tractorboy, 12-23-2003 18:13:43
valve lift ,duration and timing is identical from a 47 and maybe earlier "A" right though the 60,620 and 630. I'll check my parts CD tomorrow for the serial number break on the "A" when the cam was improved.
tractorboy
12-23-2003 21:11:07
You know I was talking about a 70 720 730 didn't you?
buickanddeere
12-24-2003 07:58:30
 Re: Re: Re: G CAM GRIND? in reply to tractorboy, 12-23-2003 21:11:07
I was talking about Tractor Boy looking for a 630 cam. I'll dig out the parts CD and find if there is any mixing and matching of the G/70 into the 720/730. I would rather have a fresh reground cam than chance a used cam anyways.
tractorboy
12-24-2003 09:03:38
 Re: Re: Re: Re: G CAM GRIND? in reply to buickanddeere, 12-24-2003 07:58:30
don't get too rough, it was just a thought
buickanddeere
12-24-2003 19:25:22
 Re: Re: Re: Re: Re: G CAM GRIND? in reply to tractorboy, 12-24-2003 09:03:38
G's from 1938 to early 1949 used the F120R cam. The G's from then to 1953 and all 70 spark ignition tractors used the F900R cam. The F900R is a factory replacememt cam for pre 49 tractors with the associated parts. The 720/730 spark ignition tractors used the F2551R cam. I'm 99% certain it had the same specs as the F900R, just a gear added to drive the distributor at 1/2 crank speed. Instead of crank speed off the governor. I can't find some of my data after moving this year.
Bus Man
12-23-2003 15:47:39
Just curious, what gear(s) do you pull in and what weight classes? What size tires are you running?
Jonathan
12-22-2003 09:49:16
I have a JD G with roberts carb,his cam grind,.125 over pistons with 6.5 to 1,2.0 ratio rockers it will lug down very good, 260pto rpm and 400lb of torque at that speed.
520-LP
12-21-2003 19:25:02
We have been pulling one with the same set up that has had the cam done {not Roberts}it will not lug either I think the compression ratio is to high for a stock stroke
buickanddeere
12-21-2003 22:48:01
 Re: Re: G CAM GRIND? in reply to 520-LP, 12-21-2003 19:25:02
Large ports and valves are for high rpm HP. Too large ports/valves or serious area of turbulance or caused by porting jobs done without a flow bench will cause port velocity to drop. Less air/fuel mixture will be rammed into the combustion chamber. And/or fuel droplets will drop out of suspension in the airflow or be slung to one side of the port.
G-MAN
12-22-2003 13:29:27
 Re: Re: Re: G CAM GRIND? in reply to buickanddeere, 12-21-2003 22:48:01
Exactly. Those large heads and/or drastically oversize valves will HURT performance in a near-stock "G", not improve it.
buickanddeere
12-22-2003 17:47:02
 Re: Re: Re: Re: G CAM GRIND? in reply to G-MAN, 12-22-2003 13:29:27
It might be worth trying a bone stock carb from a A or G tractor before tearing it apart? Doesn't even have to be a big nut 51 on that application.
