6030/619 cubic inch?
al
12-24-2003 12:57:01
How big do they make the 619 and who strokes the crank that big?
big
12-24-2003 20:49:42
 Re: 6030/619 cubic inch? in reply to al, 12-24-2003 12:57:01
they can be built to around 800 c.i. I'm not sure if anyone actually runs them that big though as it seems like it would be hard to hold together, but plenty of room in them to go big.
Bush puller
12-24-2003 15:07:25
Ntpa pro stocks build them to 680 ci turboed, Riverside builds the cranks, but I dont think they stroke the 619, just bigger bore. Southern Illinois crankshaft builds cranks for any motor, for a price of course. Don't build it quite yet though, sounds like trouble brewing in the big leagues, ci limit may be coming down, 619 never came in a two wheel drive tractor, articulaters and combines only. Ntpa and others may put a stop to it. Good luck, thats just my 25 cents.
Scott
12-25-2003 03:09:28
 Re: Re: 6030/619 cubic inch? in reply to Bush puller, 12-24-2003 15:07:25
So you think we should let Hyperpoop run steel blocks-never produced or put in any tractor by ANY manufacturer-but constantly pick on thr big block John Deere? I think we should run what we brung. Just because IH gets beat they go into Hyperwhine. If a 619 works run it. Or maybe I1ll just use a 531 block. Or do you want to outlaw that too? Keep this mentallity up and keep crippling the sport. It`ll never grow with crap like this happening.
1206SWMO
12-25-2003 08:35:37
 Re: Re: Re: 6030/619 cubic inch? in reply to Scott, 12-25-2003 03:09:28
Scott,lets look at the other side of the coin.The 619 JD motor was never offered in a TWD tractor.What other make of tractor has the luxury of bolting in a 4WD motor that huge?A 531 is fine because thats what a 5010,5020,6030 came with.
I'm not picking on 6030's because they are a great tractor and I hope to own one next year.It will just be to play with and not pull.No,it wont have a 619.
The run what you brung theory will ruin pulling quicker than anything if there are no limits.As the saying goes there is no replacement for displacement.Whats wrong with running heads up on cubic inches that most colors of tractors can reach easily?This should have been done years ago before everyone built so big.
If say you can pull a 6030 JD at 800+ cubes why would I want to build a IH having to start at 466 and go to 640 at the most.Keeping a block in one piece at 640 is hard to do.
Why would I want to build a D-21 AC starting at 426 cubes and only be able to build to 585 cubes?Why wont they let me run a N-7 Gleaner combine engine thats 516 cubes to start with?
Why would I want to build a 456 Ford and not be able to build to much over 500 cubes.I have heard of a few 600 cube Fords??
A Case is 504 to start with but I'm not sure how big you can take them.I know some are 585.The boys in Wisconsin can make them run.
A MM is 585 but how many do you see pulling?Its hard to keep a crank in one.
The big reason for the unreal engine limits to start with were the 636 Cat and 640 Perkins V-8's.However,it seems like less and less people are pulling these all the time.
If I were pulling a JD I'd love the high cubic inch limits.If I were pulling any other color I wouldnt because I cant reach those limits.I'm at a severe disadvantage to start with no matter how deep my wallet is.What if the tables were turned and all JD had was a 466 and IH had a 619?
We need more color in pulling,not just a Green and Red parade.You sure hear alot of comments about that any more.
Lets hear more opinions.
Slo
12-25-2003 19:12:05
 Re: Re: Re: Re: 6030/619 cubic inch? in reply to 1206SWMO, 12-25-2003 08:35:37
Actually, MM should be allowed to run small bellhousing 800cid engines. Vista G1000's were offered with this as a stock factory option. Very few, but they were factory. That engine was outlawed years ago.
David
12-25-2003 20:30:11
 Re: Re: Re: Re: Re: 6030/619 cubic inch? in reply to Slo, 12-25-2003 19:12:05
I don't know if they where a "factory" option, always have heard that they where dealer options. Heard from a oldtimer that A4t-1600 propane's where sent from the factory with 800HD on a crate to be installed by the dealer if the owner wanted, if not it was sent back. Don't know how reliable the info is though.
Slo
12-26-2003 18:11:24
 Re: Re: Re: Re: Re: Re: 6030/619 cubic inch? in reply to David, 12-25-2003 20:30:11
My understanding, and it's very possible I could be wrong, is that a limited number, a hundred or so, of G1000 Vistas were built with the small bell housing 800 cids as factory stock.
David
12-26-2003 19:07:28
 Re: Re: Re: Re: Re: Re: Re: 6030/619 cubic inch? in reply to Slo, 12-26-2003 18:11:24
You may be right but until someone shows FACTORY documentation I don't see them allowing them. Anyways, the cubic inch rules will not allow them anyways.
Slo
12-27-2003 17:55:25
 Re: Re: Re: Re: Re: Re: Re: Re: 6030/619 cubic inc in reply to David, 12-26-2003 19:07:28
Does the cid rule go back to Solid Junk?
ChadS
12-28-2003 13:32:35
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 6030/619 cubic in reply to Slo, 12-27-2003 17:55:25
Now there is a famous MM from the past..
Scott
12-25-2003 12:31:37
I never said we should allow 800 CID in anything. I said (or meant) that anyone should be able to run a JD 619 block at 640-680 CID the same as anyone else. If I recall the Super-Farm CID is already 640. But you should be able to run a 619 block at that CID if you want.
1206SWMO
12-25-2003 14:49:18
 Re: Re: Re: Re: Re: 6030/619 cubic inch? in reply to Scott, 12-25-2003 12:31:37
Scott, My opinion is that Pro Stock should always have been 600-620 cubes max and SF at 540 cubes.However,its too way late for that now in each class.
Almost any color could easily reach 540 in SF.For a so called starter class 640 is way too big.619's should never be allowed in SF.Use the 466 or 531.
No,I really dont think IH's should be allowed steel blocks when others dont have them avaiable.I can see why pullers want to run them as they get tired of splitting blocks open.A local IH pro stock split a block open right at the end of the season and is quitting pulling.
ChadS
12-25-2003 11:37:34
My dream tractor like that would be a g-1000 MM, on LP or alky,, just like the Hull family. Big ol moster 6 cyl, twin turbos, on alcohol, what a ride that would be huh? IH dominated pulling for years,, JD has always been in there too, but most of them were the 4020, 4010, and was kinda rare to see a 5020 or even a 6030 at a national event,, today,, that is about all you see in classes above 7500,, 5020,6030, etc,, I love to see them pull!! But the IH,, has potential,, I am talking about in the SS catagory,, Remember Leroy Mason? He had that 766 a running good, but never heard what happened after 2001. They had to change so many rules to let him pull in the classes he ran,, weight advantages,, etc,, but what I cannot understand is this,, the big boys in pulling make this a money game and the biggest HP game in the world,, what makes the difference what kind of fuel you use? To me,, it is just like pulling a gas, spark plugged engine, against a diesil,,, I know the alky story,, Seen evolution as years passed,, ran it myself,, To me,, an alky engine is the way to go,, it takes less boost, (less chance for an explosion) Some use less rpm,, not all but some do,, And you can build them easier,, like a good street engine in a car,, and make the same, if not more power and torque trhat a diesil engine.. I don't know,, I could be wrong,, What do ya all think? ChadS
1206SWMO
12-25-2003 12:13:41
 Re: Re: Re: Re: Re: 6030/619 cubic inch? in reply to ChadS, 12-25-2003 11:37:34
Chad, Check out Charles DeClerks G-1000 Vista LP turbo puller from Taylorville,ILL.I took this picture at Plesasnt Hill,ILL in Aug 1969.Those were some great times in pulling.
This 504 on LP could run with anyone in the U.S.In Sept 1969 we watched him get 2nd place out of 31 at the 1969 M&W Pull World championship pull at LaPlata,MO.He was flying when he sheared an axle key and came up 8 ft short of a 1206.
Scott
12-25-2003 13:20:56
 Re: Re: Re: Re: Re: Re: 6030/619 cubic inch? in reply to 1206SWMO, 12-25-2003 12:13:41
I forgot to ask 1206SWMO if he`s in favor of the Hyperpoop steel block or in favor of steel blocks for all colors or no steel blocks at all. Just curious to hear your response to that question.
Chads
12-25-2003 12:51:55
MMM I like that pic,, Thank you!! ChadS
1206SWMO
12-25-2003 15:13:58
 Re: Re: Re: Re: Re: Re: Re: 6030/619 cubic inch? in reply to Chads, 12-25-2003 12:51:55
Chad, Check out this MM LP puller.Its the late Bill Newlons 15,000 lb Open puller out of Prophetstown,ILL.I took this picture in Aug 1969 at Pleasant Hill,ILL.Its a G-1000 Vista running a 800 MM irrigation motor on LP and had about 450 horses which was a bunch back then.It had a Smull and Jennings LP turbo set up on it.
Bill had to pull against V-12 Allisons,318 Detroit powered JD's,a twin turbo 220 AC,1206 IH with a 573 V-8 diesel,and others.
I never got to see Leroy Mason pull the "Down N Dirty" 766 in person but got to see him on TV alot.Didnt he win 29 of 32 hooks one year in the ATPA light SS class.Just a great running tractor but Leroy got pretty upset when the diesels were given a weight advantage over the alkys.
I'm a big fan of the Hulls two alky MM pullers.Have seen both of them pull quite a few times.
I love the alky pulling tractors but I can see the frustration of trying to pull a diesel against them in the same class.What the answer is I really dont know.I'm afraid pulling has some tough times ahead of it.
I've heard it said that Brent Long could build a OHC diesel that would run with the alky burners but it wouldnt be legal.
I have lots of pulling pictures from the late 60's-early 70's.I and my brother once pulled a 12,000 lb 856 IH SS in the early 70's.sure had alot of fun.
ChadS
12-25-2003 17:17:18
 Re: Re: Re: Re: Re: Re: Re: Re: 6030/619 cubic inc in reply to 1206SWMO, 12-25-2003 15:13:58
Doesn't the unlimited SS class allow the OHC? I had the privilage to see Leroy in action at the Elkhart County fair in Goshen,Indiana, 2 years in a row,, He was selling T-shirts with the 766 on it,, got him to auotgraph it!! When Speed vision had the ATPA on every Friday night,, I tuned in,, taped every single one too. Man,, what a great running tractor, as The announcer at Goshen said,, (I belive it was J. Banet) "He likes to stand it on the wheelie bars and haul,haul,haul. Front end never touched the ground from start to finish. 2 years ago,, I seen the Blue Blazes Ford alky ram a skid loader,, guess the skid loader was in the wrong place at the wrong time huh? HA HA. Then,, the Walking Tall Ford was still a diesil,, Hot Iron, had just debued,, and the Kempers had bought their new ride, replacing the ol D-21. I love those hot summer July nights,, Got any pic of the 856?? ChadS
ChadS
12-25-2003 17:27:40
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 6030/619 cubic in reply to ChadS, 12-25-2003 17:17:18
This year at Goshen,, got to see all of the best,, Very impressive show of HP,, spinning on a sand box,, HA HA,, We pull right beside them,, just ask BUDD,, and DCTOM,, not more that 20 ft between tracks,, Got to see the Silver Bullet,, It was a nice looking ride,, If you ever get the chance to come to Goshen,In,, the ATPA puts on one heck of a show,, all of the classes they offer in one day. I have a friend of mine,, he has a 180 Allis called the smoker. He has made alot of changes over the last year,, engine is strong,, rear ends and imput shafts are breaking,, I think he won down at LFMS last year.. Local boy!! I go to about 60 pulls a year,, 20 with the club,, and about 20 with the other local clubs, and the rest are big pulls, Like I said before,,I live in a tractor pulling world,, Some day,, the ol 856 is going to be a hot farm,, then who knows??? ready for a faster tractor,, the 460H is my first 6 cyl puller,, gonna start small then work my way up.. Have a great night!! ChadS
1206SWMO
12-25-2003 18:45:01
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 6030/619 c in reply to ChadS, 12-25-2003 17:27:40
Chad, Heres my brother pulling our 12,000 lb 1968 model IH 856 SS tractor at Columbus,KS in the early 70's.Got rained out on a Sat eve and came back Sun afternoon and won the 12,000 SS class.
This was in the good old days of pulling.You worked the tractor in the field all spring,put the pulling parts on and pulled all summer,took the pulling parts back off,and worked it in the field all fall.
We probably made all of 350-400 horses but were competitive with most every one else back then.Mostly pulled against other IH's,AC's,and a few JD's.
Next year will make 40 years that I have been around pulling.
supermpuller4
12-26-2003 13:40:19
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 6030/6 in reply to 1206SWMO, 12-25-2003 18:45:01
A fellow puller asked if his 856 would pull better with a 466 cu. instead of the 407. He only needs 250 to 300 hp, whats the better set up, money wise.
1206SWMO
12-27-2003 08:15:21
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 60 in reply to supermpuller4, 12-26-2003 13:40:19
250-300 horses out of a 407 is no problem.Even with the field set up my old 856 would dyno 200 horses but we ran it at 150 to keep it from over heating.For what a good 466 costs he can have 3-400 horses out of a 407.I still see used pulling parts available for them.
I had some friends that ran a 1456 at 250 in the field with an intercooler on it.
ChadS
12-25-2003 21:29:14
Bet it made it look easy too.. I got an 856D, it has the 407DT in it. It has about 1200hrs on a rebuild, the pump has been rebuilt since then roosa master, other than that it worked all day in the fields, started up every time, and pulled a 25 ft Kewannee field cultivators, sank down in the pasture, and ran 1st high with it,, had to pull the TA back once or twice, Now days,, dad quit farming, and it sits around with a sickle mower on the back,, I keep telling him that one of these days, HA HA.. Ever break the transmission, or pinion shafts in that 856? ChadS
Job
12-28-2003 09:46:31
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 60 in reply to ChadS, 12-25-2003 21:29:14
I really enjoyed the comments and reflections on this thread. I think if all pullers looked back on past years of pulling and took a lesson everyone would get along better. I started out pulling a Cockshutt 40 SS, then built a JD 2840 SS that ran 6000lb. & 7500lb.
