Cast wheels vs pressed steel on JD 70
Old Joe
12-24-2003 12:57:42
Could anyone tell me what the weight difference per wheel is between my stock cast wheels with steel rim and pressed steel wheels and hubs for my JD 70, also can you tell me if I can use the pressed steel wheels in div. 1 div.2 and div.3 at tractor pulling events.
Thanks Old Joe
IH H Puller
12-24-2003 20:14:55
 Re: Cast wheels vs pressed steel on JD 70 in reply to Old Joe, 12-24-2003 12:57:42
Div. I does not allow pressed steel. Most Div. II and all of Div. III allow pressed steel. this is true at least where I have been pulling.
2 Cylinder
12-24-2003 20:12:36
I can't tell you what classes you can use them in, but I can tell you that there is about a 750# difference between the two.
