88 ignition
zig
01-01-2004 13:34:34
WHAT SHOULD BE DONE TO STOCK DISTIBUTER FOR 3000 RPM 440CID THANKS
Allis
01-01-2004 16:06:12
 Re: 88 ignition in reply to zig, 01-01-2004 13:34:34
just make sure the advance is working properly, I like the petronix electronic ignition for under a hundred bucks and a good 3 ohm coil. nothing wrong with a good set of napa echlin points eather, make sure they have a copper strap along the spring, cheep ones don't and there is a difference, you may want to use the old spring also to double them up but at 3000 it should be fine
