Advance on dist for A jd
mark
01-05-2004 19:40:28
what should my dist deg,s be on my delco dist, i am tring to dile it in on my dist mach, need to know what would be a good start or running deg,s, i have A A jd running div 3 I have been told 7 to 14 thin told 26 deg,s.
Gpower
01-08-2004 06:32:07
 Re: Advance on dist for A jd in reply to mark, 01-05-2004 19:40:28
Should be set at rated hp and rpm 22 degrees. Up to you though depending on your setup. High idle it we be up around 26, check the springs in the distributer and make sure the advance is moving freely. Good luck
Gpower
