70 weight problems
Ryan Teach
10-17-2001 17:49:43
Can you get a 70 into 5500 pounds???
if so, how did you do it....or how might I do it??
rick
10-18-2001 08:41:26
 Re: 70 weight problems in reply to Ryan Teach, 10-17-2001 17:49:43
You'd probably have to lose the F1500R cast rears
in favor of pressed steel and lose the roll-a-
matic for a start.
Reply
10-18-2001 07:06:27
Your going to have to be more specific. Are you talking about a 70 Oliver or a 70 Deere. The one you would have to add weight to, the other you'll have to strip everything possible off.
John Deere of course. After all.....
10-18-2001 11:36:12
 Re: Re: 70 weight problems in reply to Reply, 10-18-2001 07:06:27
this is a John Deere pulling board, Right?
Ryan Teach
10-18-2001 21:03:04
 Re: Re: Re: 70 weight problems in reply to John Deere of course. After all....., 10-18-2001 11:36:12
YOU know I asked a simple question about my weight problems with my JOHN DEERE 70. Yes, I am sorry...i should have been more specific. But there was no need to bring up the conflict below!
Let me know if there is a John Deere baord...i will be sure to go there next time!
reply
10-18-2001 14:31:07
I should have known. Olivers don't need that much help.
Deereman
10-18-2001 17:40:50
 Re: Re: Re: Re: 70 weight problems in reply to reply, 10-18-2001 14:31:07
Yeah olivers dont need that much help, they need to just be placed in the dead row...why waste time on them. Just Kidding dont get all huffy, as to the actual question, I dont think you could get a 70 in the 5500, might squeeze into the 5600 but it would be really hard. 6000 no problem. Flat back, drop the oil bath some other things...it is a gas right? Good luck
bigmotors
10-21-2001 13:58:07
 Re: Re: Re: Re: Re: 70 weight problems in reply to Deereman, 10-18-2001 17:40:50
Yes-You can get a "70" JD in 5500 lbs. class. I've seen many in 5500 lbs. with 18.4 x 38 press rims/ two of them had wide fronts! It depends on how much cutting you want to do on the tractor.
If you do not want to modify your tractor to much, then it might be tough to get it in 5500 lbs. It's like anything else, how bad do you want to pull 5500 lbs. class? You can- loss the big raditor,the big gas tank, run a MT or 40 front end,cut the axles and weld on plate hubs, make a seat and bracket,flat back,loss the power steering,cut on the frame,plastic pipes. A extra bolt here, a extra bracket there. It all adds up. There's alot of "G" out now in 4500 lbs. I now of one that can get down to 3750 lbs. !! Anything is possible. Good Luck!
Ryan Teach
10-21-2001 16:48:56
 Re: Re: Re: Re: Re: Re: 70 weight problems in reply to bigmotors, 10-21-2001 13:58:07
Would you recomend pulling a 70 there?
What perfromance parts are available to really dominated. I am pulling against some wicked oliver 88's. I am willing to spend some $$$, and really work the tractor over a lot. I have seen some 2 cylinder diesl shops...are these what I want. Are there any other ways to beef up a 70.
Thanks for you help above!
Ryan
Gpower
10-21-2001 17:49:11
 Re: Re: Re: Re: Re: Re: Re: 70 weight problems in reply to Ryan Teach, 10-21-2001 16:48:56
Is this a diesel 70 your working on? If so drop me a line with what you have and wanting to do
Ryan Teach
10-21-2001 18:52:43
 Re: Re: Re: Re: Re: Re: Re: Re: 70 weight problems in reply to Gpower, 10-21-2001 17:49:11
I pull a G right know. And I am debating going to a 70. I could use a Gas, propane, or diesel...what ever it takes to beat the 88's
KEITH
11-20-2001 11:45:24
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 70 weight problems in reply to Ryan Teach, 10-21-2001 18:52:43
IF YOUR RULES ALLOW THE 70 HEAD, MANIFOLD AND CARB
I WOULD STAY WITH THE G.
GAS OR PROPANE IS THE BEST WAY TO GO.
JIM COREY OR MARK SCHELLUM CAN HELP YOU MAKE A SET-UP LIKE THAT AN OLLIVER EATER
KEITH
11-20-2001 12:00:33
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 70 weight problems in reply to KEITH, 11-20-2001 11:45:24
JIM COREY RUNS FORTH GEAR WITH 18.4 X 38'S ON A GOOD TRACK, THAT IS HAULING THE MAIL.
I COULD HELP YOU WITH A CRANK IF YOU WOULD LIKE TO GET TO THAT LEVEL
KEITH MERFELD 563-582-8710
Ryan Teach
10-21-2001 18:52:34
