203 combine motor?
Family Traditio
01-06-2004 16:57:40
what is this worth?
Shaggy
01-07-2004 11:28:40
 Re: 203 combine motor? in reply to Family Tradition, 01-06-2004 16:57:40
Is this the the motor that has around 153 Cid?I have been told it will work in A,B or C. From what I have found in the engine book at Carquest a engine like this is the same as a H. I might be wrong about some of this but still curious.Whats the bore and stroke? Thanks
SMTA PULLER
01-07-2004 18:52:06
 Re: Re: 203 combine motor? in reply to Shaggy, 01-07-2004 11:28:40
Shaggy the bore is 3.370 and the stroke is 4.30 and the rated load engine r.p.m.is 2320.DYNO AT 50 HP.seen two SC and one 230 at NATPA pull at Wichita
farmall
01-07-2004 15:55:52
The combine motor is NOT the same as an 'H'. If you plan on running one you better check with your club first. NATPA does'nt allow this engine anymore in an 'A', 'B', or 'C'. But you can a 230. Go figure.
Shaggy
01-07-2004 21:43:34
 Re: Re: Re: 203 combine motor? in reply to farmall, 01-07-2004 15:55:52
It will probably be just a toy because we don't have a class for the light weights around here. What I could use now is a manifold off a 140 or maybe a 230. The one I have seen are a colder manifold than the ones I have.
randy hall
01-06-2004 22:16:16
i sold two real good ones this past year for $400 each.
