D361
Ron 1456
01-11-2004 19:32:24
Can the IH D361 block be bored out to accept 407 sleeves? If so can the 407 pistons be used with the 361 crankshaft and connecting rods?
E J
01-12-2004 14:59:15
 Re: D361 in reply to Ron 1456, 01-11-2004 19:32:24
You have two differnt strokes.361 is 4.5,407 is 4.625.Pistons have different pin heights .Just stroke the crank and put case 504 pistons in it and have a 466.
Ron 1456
01-12-2004 16:04:41
 Re: Re: D361 in reply to E J, 01-12-2004 14:59:15
Thanks for the response and tell me more. This sounds very interesting. I was aware of the difference in the strokes and wondered if the pin heights would be different. What connecting rods and sleeves would you use with the Case pistons? Ron
Chads
01-12-2004 20:09:54
 Re: Re: Re: D361 in reply to Ron 1456, 01-12-2004 16:04:41
What is the make and model of the turbo off of a 1256-1456?? Our 856 has the DT407,, just curious,,,, Chad
farmer don
01-13-2004 04:17:43
 Re: Re: Re: Re: D361 in reply to Chads, 01-12-2004 20:09:54
Swi***zer (sp) is the stock bolt on. TO4 takes an adapter plate,but will keep the fire down when the plowing gets hard. Run 17#s compared to the stock 8 on 361. Pulled an 11 shank IH 55 chisel.The pump is a little bigger to.
