G model JD is 421.5 cubes stock
johndeere_john
01-12-2004 09:22:17
Boring to .125 over gains 17 cubic in, or to 429.5, how much horse power increase can you expect?
Jon
a puller
01-12-2004 16:07:53
 Re: G model JD is 421.5 cubes stock in reply to johndeere_john, 01-12-2004 09:22:17
A G John Deere is 413 cubes stock, and with .125 alum. it is 430 cubes.....We have one with a flathead and .090 pistons with 68hp.
toot
01-12-2004 14:02:54
if you're going from cast iron flat tops to the higher compression aluminum pistons, shave the head .250 and properly tune it, horsepower will be 50-55 range. Been there done that with a dyno.
buickanddeere
01-12-2004 11:32:33
A whole 1.5 HP or 4% more at most figuring the stock and the over bore seal the same. The intake system will not quit keep up with the extra airflow so 1.5HP is optimistic.
yeah, but
01-12-2004 13:48:04
 Re: Re: G model JD is 421.5 cubes stock in reply to buickanddeere, 01-12-2004 11:32:33
if that's going from regular to gas pistons you're gaining compression there too. Most people say about a 5 hp gain.
buickanddeere
01-12-2004 17:16:19
 Re: Re: Re: G model JD is 421.5 cubes stock in reply to yeah, but, 01-12-2004 13:48:04
He didn't say anything about mods other than increasing the bore. If doing other mods just machine the bore the minimun to get round holes, rather than going 125 over standard. A power block is required to gain serious HP from an overbore and stroking. The stock 4 to 1 compression of a G puts most of the gasoline fuel energy up the stack. If the fuel will pour and burn, a stock G will run on it. After all that's what Mother Deere intended back in the 30's. Valves, valve bowls and cam need work to improve breathing.
johndeere_john
01-12-2004 13:07:38
I also plan on converting the oil bath air cleaner to a dry filter insert, this will proably get me more than the over bore.
Jon
Tyler Neff
01-12-2004 20:33:56
 Re: Re: Re: G model JD is 421.5 cubes stock in reply to johndeere_john, 01-12-2004 13:07:38
I built a G years ago that was .125 over . I also planed the head .125 and the front and back of the block .125 . I dont really remember what kind of compression it had. Other than that I did nothing and had around 62hp.It just depend on what you wanna do with it plow or pull?
