Big Farmall
Donnie
01-19-2004 14:04:19
How much work does it take to make a "Big" Farmall M engine. I would start out with a 450 or 400 block. I would like a 7" or a 7 1/4 stroke. What combo works best. What pistons? Stock rods or made ones? How much clearance on the block and rod sides and cam shaft? I know about the lp head and big carb. Just wondering if a fellow could do it him self. Oh yeah what size would be best for the rod journals? I've done a 5/14" H motor. But this might be more taxing for a simple mind. Any help would be nice. Thanks. Donnie
farmall
01-21-2004 07:03:22
 Re: Big Farmall in reply to Donnie, 01-19-2004 14:04:19
A 7.25 stroke is MAX for a stock rod. At this stroke the average puller would pull there hair out putting it in and give up. I have several of these out, and work verry well. As far as clearence goes, a good rule of thumb is .050 min.
also put flats on camshaft to clear rod. If you are trying to keep up with Lemmons, You will need more stroke. Their later motors are 7.75 to 8" stroke. Very strong and torquey. Good luck. But if it were me, I would opt for at least 600 cubes for div 4 classes
Hope this helps
Donnie
01-20-2004 07:55:30
Thanks for all the help. I now see why its always the same 4 or 5 people on here. Must not like outsiders. Donnie
Ohio M Puller
01-20-2004 08:52:21
 Re: Re: Big Farmall in reply to Donnie, 01-20-2004 07:55:30
Donnie,
Here is part of your home work for you. A chysler 440 piston at 4.33 bore will work with a stock 450 rod (Pin Diameter the same) Stroke crank to 7.375 ( 7 3/8 ) will need to do ALOT of grinding but you are welcome for the FREE info this will make 434 cubes just cause I am sure will be wondering. Now go ahead and cut on everyone else on here cause they don't want to just hand out their motor dimensions. And no this is not what is in mine. Your welcome cause I am sure it will be to tuff to say thanks.....
Ohio M Puller
Flyin Farmall
01-20-2004 16:17:21
 Re: Re: Re: Big Farmall in reply to Ohio M Puller, 01-20-2004 08:52:21
That stroke sounds kinda big for a stock rod??
Donnie
01-20-2004 09:27:54
First of all, thanks for the info. It is never TUFF to say thanks when you are being helped. THANK YOU. I was just wanting some ideas to what some of you fellas are running. That crank stroke sounds huge. Sounds like it sould have a lot of torque. I live in Central Ind and would have to run against some very tuff Rushville M's. Just like to do something so I won't keep dragging last place all the time. Kinda gets old. Thanks again for you help. It was very much appericated. Donnie
fergfarm
01-21-2004 15:43:54
 Re: Re: Re: Re: Big Farmall in reply to Donnie, 01-20-2004 09:27:54
400 M WITH 6.250 STROKE,JUST A BACRYARD MECHANIC.WITH ALL THE GRINDING TO GET THIS,IF YOU ARE GOING TO PUT THAT MUCH WORK INTO GOING 7.0 WITH STOCK RODS YOU MIGHT AS WELL GO TO 4.5 BORE.HAD ROSS TO MAKE THE PISTONS FOR ABOUT PRICE AS STOCK SLEEVE ASSEMBLY.
