Farmall H Bore Size
Dave
01-22-2004 18:04:15
What is the standard bore size of a 1944 H without the liners? What pistons can be used?
ChadS
01-22-2004 18:14:07
 Re: Farmall H Bore Size in reply to Dave, 01-22-2004 18:04:15
Any of the 6 cyl IH pistons except the 301 will work in a H block,, you will have to bore it. I am thinking,, and it depends on if it has thin or thick wall sleeves. the biggest bore possible in a H without aftermarket sleeves is 3-13/16. If you choose to run aftermarket sleeves,, go out to 4in, stock stroke, Use Massey 44 pistons (out of 4 cyl cont, gas engine) Same comp height as the H,, you will have to make wrist pin bushings to adapt the different size wrist pin to the H rod. Makes 213ci. Hope this helps,, I have a big bore H block That needs a new home,, it is a spare I had built and never used. Email me if you may be interested. ChadS
tractorboy
01-22-2004 19:09:56
 Re: Re: Farmall H Bore Size in reply to ChadS, 01-22-2004 18:14:07
What do you want for your block?
