560 bore
zig
01-25-2004 13:08:44
what is the largest bore i can go iam going to run solid block thanks
bigmotors
01-25-2004 18:04:57
 Re: 560 bore in reply to zig, 01-25-2004 13:08:44
If you want it to live and to still run water/ 4.155 bore with 5.750 stroke. Any bigger, you have to go to church twice on Sunday. I've heard 4.200 X 6 with hard block. Never saw the motor run.
Good Luck!
ChadS
01-25-2004 16:19:26
I am not for sure about the sleeved engine blocks,, but on the sleeveless 6 cyl IH, the block can be bored out to 4-1/8 very easily and still have 150 wall thickness. I bought a 403 engine a week or so ago, and had a piston break the sleeve, (block) so I finished breaking it with a hammer to see how thick the wall was, it measured .475 thick. Nice meaty block in my opinion. Would make an indestructable 301 at 3-13/16+ .060 in my opinion. you find these sleeveless blocks in IH 403 combines. They are everywhere. they are 263 to start with, I hve one in a H tractor,, bone stock, on reg gas was 70+hp. Hope this helps,, Chad
farmall 460
01-28-2004 17:40:55
 Re: Re: 560 bore in reply to ChadS, 01-25-2004 16:19:26
what is the difference between the 560,the 460, and the 301 combine engine? and how far can you bore out and stroke each for max. power
ChadS
01-31-2004 19:47:08
 Re: Re: Re: 560 bore in reply to farmall 460, 01-28-2004 17:40:55
460 had a 221, 3-9/16X3-3/4 stroke. 560 had a 4.25 stroke, and the 301 has a 3-13/16 bore and 4-25/64 stroke, Have heard of 400 inch 6 cyl engine, I would use a 403 combine block, has a sleeveless block and thicker walled sleeves than the wet sleeve 301 (806 etc) Not for sure how much stroke you can stuff in there, Look for a old Ih truck head off off the 301 truck engine, they were a bit stronger than the tractor engines. Might make a decent 100 hp easy out of a 301, or bigger piston, stock stroke, 460-560 puller engine. Just my opinion, chadS
