Ford 2N turn puller?
Bill in Orono,
01-25-2004 18:57:03
Hello,
I'm going to be rebuilding my 1946 Ford 2N this summer and I want to make it a bit of a puller.
What can I do to the ol' thing to get 30+HP from it. Stock is something like 24-25HP.
Any one know of a supplier of high performance pistons, or manifolds?
I am thinking of having a tube intake and exhaust manifold made and installing a larger carb-although I don't know what one or type.
Any suggestions will be greatly appreciated.
Are You
01-27-2004 00:03:11
 Re: Ford 2N turn puller? in reply to Bill in Orono, MN, 01-25-2004 18:57:03
..... ...going to pull it in the lawn tractor class so it can compete?
PeteNY
01-27-2004 06:45:35
 Re: Re: Ford 2N turn puller? in reply to Are You, 01-27-2004 00:03:11
And what may I ask do you pull in the lighter classes? Chances are someone around here mighta beat whatever you pull with at one time or another!
Green Weenie
01-27-2004 11:10:23
 Re: Re: Re: Ford 2N turn puller? in reply to PeteNY, 01-27-2004 06:45:35
Not trying to be a wise acre but as expensive as the small Fords are in the Nebraska suburbs we can not afford to turn one into a puller,are they that common in your area? Also when you build one how comparable is it to building the old flat head V8s,I think it would be a real hoot to build one!!
ChadS
01-27-2004 12:30:41
 Re: Re: Re: Re: Ford 2N turn puller? in reply to Green Weenie, 01-27-2004 11:10:23
I have a friend that has one of those with the flatheads it it,,, he has 2 or 3 carbs on it,, It is just a play toy,, seen it pull once,, done well, smoked those little tires on there!!! Fords are cool!! I think they could be very underestimated,, especially with the Funks 6 cyl conversion. I think that is right, 6 cyl and v8's right? Chad
Chris Brown
01-26-2004 17:24:26
I've been thinkin the same thing. I know that breathing is a big deal on that engine,just pulling off the air cleaner makes a difference.I have ben looking for a high speed /pressure 12 volt blower to try. The tube manifold would have to be a good start. I would'nt mess around with running no sleeves. A custom cam shop could grind your cam to run right.That engine will turn the same rpm's as a flathead V8 ,4000 should'nt hurt it if the bottom end is tight. I read about an 8N with the flathead that'd do 65 mph,that'd have to be a hummin motor at that speed.
PeteNY
01-26-2004 16:24:23
I meant Bill...sorry, also don't forget to get that draw bar up as high as they'll let ya...sometimes the tech guys don't figure a "lowly N" will do much so they tend to over look that extra 1 or 2 inches of drawbar height. Pete
mike
01-26-2004 07:56:05
if you want a puller, get a different tractor
fords arnt much
PeteNY
01-26-2004 16:21:53
 Re: Re: Ford 2N turn puller? in reply to mike, 01-26-2004 07:56:05
Mike, I looked into this when we rebilt ours, you're on the right track...breathing is the issue, bigger pistons, shaved head and such don't make a BIG difference. Guys have modified the intake and used bigger carbs, but I pull NATPA and that would kick it up into a higher modified division and I didn't want that for 2 reasons, 1; I like my tractors near stock, 2; those tractors that you are trying to compete with are more easily modified with better results, so they get even stronger. We have had good luck in Div 1 with ours at #3000 and to some extent #3500. At #2500 she'll beat the Farmall A's and such, but if you get it that light it's tough to weight it up enough to play in the higher classes. We pick our spots; slick tracks, are the best on ours, harder tracks, and the Farmall C and SC, and Olie Super 66s are just too much. As far as the up/down tranny, we didn't feel that low 1st was all that much of an advantage as you never get any momentum built up. Have Fun! Pete
Mike S
01-26-2004 06:57:55
I was told the guys in my club run no sleeves and use Ford flat head V-8 pistons.
marlowe
01-25-2004 21:03:33
i pull a to-20 freguson up to 4000 100% stock but do have a 3 speed sherman. pulled 4 times last year 3 first 1 sec. is real good on blacktop at 2800. 4000 is a little much going to stay below 3500 this year
Farmallgod
01-25-2004 20:01:10
Bill from what i've seen they are geared to high and it would be more of a hassle than what it's worth.
8-n puller
01-25-2004 20:35:50
 Re: Re: Ford 2N turn puller? in reply to Farmallgod, 01-25-2004 20:01:10
First you need a step-down transmission or shorter tires to slow your ground speed. Bore it out, plane the head, give it a little stroke, rejet the carb, port the head & exhaust, new springs & valves, go to a bigger exhaust and add a free flowing air cleaner. This will give you more than what your looking for and won't break the bank. Worked for me! Of all the above, slowing the ground speed while maintaining RPMS is the most important part of Ford pulling.
phil
01-25-2004 21:04:17
 Re: Re: Re: Ford 2N turn puller? in reply to 8-n puller, 01-25-2004 20:35:50
The 2 companies that supplied the Over/Under trans for the Fords were Sherman & Hupp. Sherman had the lever on the left, Hupp was on the right. Both provided 12 gears forward & 3 reverses. The 24 HP might be enough in Underdrive-first.
