Custom Pistons
Matt
01-26-2004 14:08:12
Where could I find a set of 4 inch pistons and sleeves that will fit an Farmall 300 rod and have the same compression height as the stock pistons? Who makes custom pistons?? Thanks.
fergfarm
01-26-2004 14:16:44
 Re: Custom Pistons in reply to Matt, 01-26-2004 14:08:12
Ross or Aries will make anything you want.If i was going to go the expense of the 4 inch pistons.then you might as well add some mopre stroke.
ChadS
01-26-2004 16:51:55
 Re: Re: Custom Pistons in reply to fergfarm, 01-26-2004 14:16:44
Use a set of Massey 44 (4cyl continental gas) pistons. will work with stock stroke. Chad
Matt
01-26-2004 18:34:19
 Re: Re: Re: Custom Pistons in reply to ChadS, 01-26-2004 16:51:55
What is involved in making the 44 massy pistons work with the IH 300 rods?
ChadS
01-26-2004 18:55:29
 Re: Re: Re: Re: Custom Pistons in reply to Matt, 01-26-2004 18:34:19
here are the specs between the 2, IH 300:
2.5 compression height
4.4375 length
.8749 wrist pin
Massey 44
2.5 comp height
4-5/16 length
1.25 wrist pin
The 300 rods have a thicker wrist pin bushing, you coould bore the rod and install the massey 44 wrist pin bushing. 300 rod has plenty of material to do this. Hope this helps Chad
Matt
01-27-2004 06:43:04
 Re: Re: Re: Re: Re: Custom Pistons in reply to ChadS, 01-26-2004 18:55:29
Another stupid question but the Massy 44 piston is taller than the 300. Will this be a problem or is there enough clearence for the piston to miss??
Thanks.
ChadS
01-27-2004 07:46:40
 Re: Re: Re: Re: Re: Re: Custom Pistons in reply to Matt, 01-27-2004 06:43:04
No,, same compression height as the 300, just a longer skirt. Compression height is the distance from the center of the wrist pin to the top of the piston. Length is the over all length of the piston. Hope this helps Chad
