Glen Rose show pull
Dale Eubanks
01-26-2004 14:21:00
Hi. Anybody know anything about the pull?. Heard it was going to be HP. pull, how does this work,what about the weight? What are the rules? Hate to sound stupid,but a long ways to haul a tractor and not be able to compet!! Dale in Tx.
JDGnut
01-26-2004 17:07:12
 Re: Glen Rose show pull in reply to Dale Eubanks, 01-26-2004 14:21:00
In the HP pulls.. tractors are divided into stock hp.. (ex.. 16-20hp,21-25hp,26-30hp.. and so on..) then there will be weighted and non weighted in each HP class... Water in the tires does not count as weight.. water in the tires is OK for the non weighted classes.. (The bigger the tires the better.. more water=more weight) What ever you can hang on the tractor for the weighted classes.. And U name it.. can be used for weight.. Concrete, railroad iron, water.. lead... Some times I go to 1 or 2 of these a year to see friends.. (didn't make any last year..) Just got tired of haulling all the weight.. and only get to pull ONE TIME.... (Unless you go for the non-weighted.. and then pile it all on.... have done that before too..) JDGnut
colekicker
01-26-2004 15:28:58
So, if you have weights, you are in a weighted class. If you don't have weights, you are in a non-weighted class. Don't know about drawbar height. Water in tires is allowed for non-weighted I believe.
Red
01-26-2004 18:38:14
 Re: Re: Glen Rose show pull in reply to colekicker, 01-26-2004 15:28:58
hey guys, Somebody said something about the sled in the last post abou this. the Burleson sled, Dont quite remember. Where is this sled from what does it look like. JDGNut have we ever pulled it before, I dont know????? Probably wont be able to make it but I am twisting my gut trying to place this sled. Later
Gpower
01-27-2004 06:32:34
 Re: Re: Re: Glen Rose show pull in reply to Red, 01-26-2004 18:38:14
Red, the Burleson sled is Tuckers, I would doubt youve seen it unless you pulled in Alvarado, Burleson or any in that area. Also I was told the other day that Botlinger is bringing the sled now, which is from around Hamilton area. It is a big yellow sled...least it was 3 years ago. Anyhow, Tuckers is gray if I recall. We are in Arkansas, and will be going to Mississippi this weekend for a pull... Take it easy
Gpower
Red
01-27-2004 11:29:39
 Re: Re: Re: Re: Glen Rose show pull in reply to Gpower, 01-27-2004 06:32:34
Good Luck guys, Hope all goes well and even though yall pull "the other color" hope you put the hurt on them. See you when the season starts up. Red
