Farmall H/300 propane head
Farm w/Junk
01-27-2004 20:25:56
Hi I was wondering if the head off a 300 propane would fit an H? Would there be any hp increase? Would the pistons help also? Would a gas head go on the propane and run? I am thinking about buying the tractor stealing the head putting a gas head on and selling it. Would that work? Thanks
Matt
WILDMAN
01-28-2004 07:59:10
 Re: Farmall H/300 propane head in reply to Farm w/Junk, 01-27-2004 20:25:56
WILL INCREASE COMPRESSON THEREFORE INCREASE HP.I RUN FLAT TOPS IN MY H WITH ABOUT 295 COMPRESSON PER CYLINDER.
a puller
01-28-2004 16:28:33
 Re: Re: Farmall H/300 propane head in reply to WILDMAN, 01-28-2004 07:59:10
how do you measure the cranking compression if its above 300psi??
farmall
01-28-2004 17:32:59
 Re: Re: Re: Farmall H/300 propane head in reply to a puller, 01-28-2004 16:28:33
Put in a new gauge that reads higher in your compression tester.
Flogger
01-28-2004 08:13:04
Hey WILDMAN,
Do you tink OTTPA would allow that Johnson LP intake and exhaust in the stock classes?
wildman
01-28-2004 09:15:48
 Re: Re: Re: Farmall H/300 propane head in reply to Flogger, 01-28-2004 08:13:04
they should .isse no problems because it looks stock.
