H front end?
kyfarmall
01-28-2004 13:38:31
Will the hubs bearings and all swap out off a 300 utility? Thanks for any help
Ohio H
01-28-2004 17:07:52
 Re: H front end? in reply to kyfarmall, 01-28-2004 13:38:31
Kyfarmall & Chad; yea, I have utility hubs on my H. Used H bearings and all, only difference was the lock nut on the H was too big to fit under the smaller util. dust covers. A local industrial supply had usable lock nuts. Also have very light KUBOTA 15" six bolt wheels applied, just had to oval the bolt holes slightly. Where is the KyFarmall from; I'm in Portsmouth O.
ChadS
01-28-2004 16:03:14
I am not for sure,, The spindle may be shorter than the row crops,, If you can find a McCormick wagon gear the hubs will interchange with the H-350. The 460 utility hubs interchange with the H,, I just bought a set for my H, and they worked fine, Hope this helps, Chad
