450 roosamaster pump
puller
02-01-2004 06:33:39
I am interested in buying one and to know what tractor they come off from. thanks a lot.
p-c-y
02-01-2004 18:02:05
 Re: 450 roosamaster pump in reply to puller, 02-01-2004 06:33:39
the 45 came stock on one of the old farmall crawlers
WTW
02-01-2004 08:34:34
Got one and it is for sale. Only ran a few pulls and was taken off and replaced with a "P" pump. Email me if interested. DW
WHAT WILL IT FIT???
02-02-2004 16:33:06
 Re: Re: 450 roosamaster pump in reply to WTW, 02-01-2004 08:34:34
I have a turboed 404 will it fit it? And what will it take to make it work? What is your asking price?
WTW
02-02-2004 20:46:49
 Re: Re: Re: 450 roosamaster pump in reply to WHAT WILL IT FIT???, 02-02-2004 16:33:06
If your 404 has a distributor type pump it can be setup to fit it depending on which 404 you have. There is about six different series of 404 that would change the application. It can be set up to work on any brand of tractor with the correct parts and housing. the real issue if you are wanting a pump to pull with it is a big plunger 450 head with very little run on it. The 450 head is the heart of these high delivery distributor pumps. Will produce a little over 300 cc of fuel depending on setup. Price will depend on if you want to buy it the way it is or have it setup to mount and be ready to run. Was previously on a Minnie Moline. Let me know how you want to buy it and I would be happy to price it. Thank You, Dave W.
JDGnut
02-02-2004 19:18:10
Which 404 do you have??? Is it the old 404 with the dist pump.. or later with the pump mounted to the front plate???.. Send WTW an email... JDGnut
1256 Puller
02-01-2004 12:20:18
I'm also seeking info on the 390 and 450cc pumps.What were they used on and what if anything , could be machined or modified on my stock roosamaster on my 1256 to make it equal to one?
greg
02-01-2004 15:57:29
 Re: Re: Re: 450 roosamaster pump in reply to 1256 Puller, 02-01-2004 12:20:18
Increase output flow on roosamaster by increasing roller to roller dimension by "tightening" screw retaining "leaf spring" holding rollers. 1/4 turn will provide amazing results.
02-01-2004 11:09:16
How in the He## did both the poster and reply have the same IP address??? Amazing, one in a million shot!!!
