Cleveland, MS pull
Spotter
02-02-2004 22:56:08
Does anyone need any info on the Cleveland, MS pull this week-end? If so let me know 'cause Mr. M. and I will probably be leaving early Friday and won't be able to post after Thursday night. The rules are those posted on Greenpullers.com.
Spotter
Moose
02-04-2004 15:37:43
 Re: Cleveland, MS pull in reply to Spotter, 02-02-2004 22:56:08
What time does it start? Thanks for the directions. I think that I can find it now.
Spotter
02-04-2004 21:51:00
 Re: Re: Cleveland, MS pull in reply to Moose, 02-04-2004 15:37:43
Moose, we usually have play pulls begining around 9:00-9:30 AM..... Spotter
Hillbilly Hooker
02-03-2004 20:18:56
Hey Spotter, where are yall staying. We usually stay at the best western on south-end. We are thinking of staying alittle closer to pull. Maybe Hampton Inn or Comfort Inn. Havent decided yet. Looks like Me and The Big Piston will be the only ones of our bunch making the trip. Sounds like Krauthead is gonna weiner-out on us and two-tone is not going to make it home in time to come. H.H.
Spotter
02-03-2004 21:30:49
 Re: Re: Cleveland, MS pull in reply to Hillbilly Hooker, 02-03-2004 20:18:56
I think Mr. M. has us at the Comfort in. You know all I do is go along for the ride and poke at the ground with a stick. He said a lot of the places were filled up. Might should call ahead and make reservations....Spotter
Moose
02-03-2004 16:23:51
Hey Spotter,
Where exactly and what time does the pull in Cleveland start? I went to Booneville last Saturday and had a blast. I'm going to try to make Cleveland if I can.
Spotter
02-04-2004 09:42:26
 Re: Re: Cleveland, MS pull in reply to Moose, 02-03-2004 16:23:51
Moose....We always come into Cleveland from the North on Hwy 61. I'm not sure of the street name but we turn left at a Texaco station that is on our left. There is a Mexican styled building to the left as well. The turn is well before we get into Cleveland proper. The pull will be in the Bolivar County Expo Center. If you have any problems just ask someone where the Expo Center is. There are usually some hand-made signs referring to a "tractor pull" on the corner.
Hope this helps....Spotter
Moose
02-04-2004 15:36:14
 Re: Re: Re: Cleveland, MS pull in reply to Spotter, 02-04-2004 09:42:26
Thanks everyone. I think that I can find it now. I will be coming from Vicksburg so I will be coming in to Cleveland from the south.
By the way, what time does it start?
Spotter
02-04-2004 10:14:47
Moose..turn off 61 HWY onto 1st street..Spotter
Hillbilly Hooker
02-03-2004 20:12:30
If I remember correctly. On the main drag thru Cleveland look for John Deere dealer and the pull is directly north of JD dealer. Hope I am right. H.H.
Spotter
02-03-2004 20:15:37
 Re: Re: Re: Cleveland, MS pull in reply to Hillbilly Hooker, 02-03-2004 20:12:30
HH..is it in the Industrial Park or do they refer to it as the Fairgrounds?...Spotter
Hillybilly Hookee
02-03-2004 20:22:03
 Re: Re: Re: Re: Cleveland, MS pull in reply to Spotter, 02-03-2004 20:15:37
Seems like they call it the fairgrounds. Maybe the Cohoma co. fair grounds. Not sure. H.H.
Spotter
02-03-2004 19:50:16
Moose, I don't know the names of streets to direct you. I'll get back. Where will you be coming from?...Spotter
