M pulling motor again
farmall flogger
10-30-2001 09:49:00
Thanks to all you guys for your help. The M&W piston sounds pretty good. Does anybody know if that piston takes a M size wrist pin or a 400-450 size. And does this piston use a sleeve? I've been told both ways. I know the block will have to be bored.
Dale13
10-31-2001 11:25:47
 Re: M pulling motor again in reply to farmall flogger, 10-30-2001 09:49:00
Piston pin size depends on the # kit you order,if they have the smaller pins you buy the bushings.You want the smaller pins.They are lighter,in fact use chevy 454 pins,stronger and lighter yet.Yes they use sleeves.Block boring depends on how big you go.
rcp
11-01-2001 08:48:17
 Re: Re: M pulling motor again in reply to Dale13, 10-31-2001 11:25:47
Is there a source on the net that lists the various M&W piston kits?
