ALLIS WD COMPARED TO D-17
CASEY
10-30-2001 18:44:22
I WAS WONDERING IF YOU CAN PUT A D-17 CRANK AND SLEEVS IN A WD BLOCK. ALSO DO THE D-17 USE DIFFERENT RODS THAN A WD OR JUST DIFFERENT PISTONS. THANK YOU
agco puller
11-01-2001 11:39:24
 Re: ALLIS WD COMPARED TO D-17 in reply to CASEY, 10-30-2001 18:44:22
Are you using a WC/WD block casting #U3019 or
a WD45 block casting #AM3853? The sleeves will be
interchange but most places sell the sleeves with piston kits. The D17's use a larger diameter main journals 3.000 inches I believe to the WC/WD/WD45's 2.750. Bearing life I suspect as reason for change.
Since all W-series engines use the same rod journal length and diameter you'll be OK there. You could grind the main journal's down to 2.750 or align bore the block and main caps up to 3.000.
KB
11-02-2001 09:13:48
 Re: Re: ALLIS WD COMPARED TO D-17 in reply to agco puller, 11-01-2001 11:39:24
All of this is accurate.... so, just put the D-17 motor in the WC.... they bolt right in.
