Best tire for the Wheel
WDIan
02-08-2004 18:34:40
Hi,
I going to be buy tire for a tractor that i pull in the 3500 and 4500 pound class in a Antique tractor pull. the wheel size is 12x28 and the current size tire is 14.9x28. they look kinda rounded on there but that could just be from wear. The proper size for that wheel is 13.6x28.
Replacement
Tire/TITAN HI-TRACTION LUG RADIAL R-1
Which size would bring the best traction.
Thanks alot in advance
JPatton
02-08-2004 18:43:56
 Re: Best tire for the Wheel in reply to WDIan , 02-08-2004 18:34:40
WD
Before you get too far along in your tire quest, there are a couple things to consider. Check your local rules. A lot of clubs will not let radial tires pull in the antique class. Also most clubs limit tire size. If you can use the 14.9, they will give you the bigger foot print and would work better on a 13 inch wheel. Hope this helps and good luck. JPatton
