300 utility puller
ron
02-11-2004 00:51:15
has anyone pulled a 300 international utility before? are they comparable to a farmall h or m? better or worse? thanks all....
WILDMAN
02-11-2004 04:37:28
 Re: 300 utility puller in reply to ron, 02-11-2004 00:51:15
BETTER BECAUSE OF HIGHER RPM RATING.
ChadS
02-12-2004 14:34:18
 Re: Re: 300 utility puller in reply to WILDMAN, 02-11-2004 04:37:28
Also has a fast rear end if you put on 38 inch tires. Would be the same as installing a W4 ring and pinion in a H. Some had TA too, My utility choice would be a 460 utility, not much to them and almost identical to the 350 utility rear end, but with a 6 cyl!! Maybe find a industrial 460 or 350, basicly the same. Chad
