Jd carb
hank
11-04-2001 17:25:32
what carb would be recommended for a 5 7/8 by 9.00 unstyled jd a.Thanks in advance.
KEITH
11-20-2001 16:14:53
 Re: jd carb in reply to hank, 11-04-2001 17:25:32
I HAVE FOUND THAT A 71 WILL DO EVERYTHING A 51 WILL JUST CHEAPER, EITHER ONE NEEDS TO BE BORED THE NOOZLE SHORTENED AND THE BOWEL VENTED EXTERNALY. YOU WILL ALSO NEED TO FEED THE GAS BETTER THAN THE STOCK SET UP
KEITH MERFELD
Gman
11-04-2001 18:04:06
Hank I assume 5 7/8 bore and nine in. stroke,if so you will need a DLTX-51. I'm hearing that a two barrel off a 70 will be legal this comming year for A's & G's. Gman
JDGnut
11-08-2001 14:09:24
 Re: Re: jd carb in reply to Gman, 11-04-2001 18:04:06
Gman, is that for Div IV and V??? or does that include Div III?? JDGnut
