Allis power unit engine for 210
cs
11-07-2001 18:26:58
Need to know if Allis made any large diesel power units that will bolt into a 210 Allis tractor?. If so were could a guy find one for sale? Thanks CS
agco puller
11-08-2001 07:52:41
 Re: Allis power unit engine for 210 in reply to cs, 11-07-2001 18:26:58
If you extended your frame you could use the 844 cubic inch plant out of the crawlers. Dual exhaust
and twin turbo's (1) turbo per 3 cylinders. This is the same engine used in the 8550 4wd's with a larger bore. I believe the 8550 was only 731 cubes. Any large construction salvage yard should have some of these.
