Cockshutt 40 PTO
Jerry
03-01-2004 13:03:29
I am getting ready to weigh the 40 that I have been working on but haven't removed the PTO. Does anyone know how much weight would be removed if I took it off? Is it a big job?
heavy
03-01-2004 14:16:47
 Re: Cockshutt 40 PTO in reply to Jerry, 03-01-2004 13:03:29
they're 100+ pounds...maybe 150 or so, that's just a guess. enough where I've found it easier to drag than carry.
it's been a long time since I've messed with one, but I think once remove it leaves a shaft or tube hollow where any oil splashed could run down it directly onto the clutch. be sure and check that out. like I said I'm pretty hazy cause it's been a while since i've worked on one.
max puller
03-01-2004 17:16:27
 Re: Re: Cockshutt 40 PTO in reply to heavy, 03-01-2004 14:16:47
Heavy you let me foregot to send the part for your brake peddles home with you do you still need it?
Jerry
03-02-2004 04:40:48
 Re: Re: Re: Cockshutt 40 PTO in reply to max puller, 03-01-2004 17:16:27
Thanks for reminding me about the oil problem. Its probably possible to plug the tube but might not be worth the effort. Jerry
Heavy Puller
03-02-2004 04:40:07
That wasn't me you think I would admit to dragging a lpto unit for one of these treasures.I found the brake piece this morning on my parts pallet with the snow gone I forgot how many treasures I had .
