HELP WITH 1949 JOHN DEERE B PULLER
MIKE LOKAI
03-02-2004 16:56:59
RECENTLY ENTERED A JD B AT FLYWHEELER PULL,
UNFORTUNATELY MY TRACTOR WEIGHT ENDED UP IN THE 5000 POUND CLASS.IS THIS TRACTOR SERIES NOT GOOD FOR PULLING (HAS CAST WHEELS,FENDERS AND STEEPS NO ADDITIONAL WHEEL OR FRAME WEIGHTS.SEEMS TO HAVE PLENTY OF POWER (RECENT ENGINE OVERHAUL/NEW MAGNETO,CARBURATOR.DID NOT STALL OUT,BUT RATHER SPUN OUT.ALL THE OTHER JD B WERE IN THE 4500 POUND CLASS. AM I WAISTING MY TIME?
Fantasy 560
03-03-2004 16:24:32
 Re: HELP WITH 1949 JOHN DEERE B PULLER in reply to MIKE LOKAI, 03-02-2004 16:56:59
We pull in North Eastern Md, Southern Pa, and De, there is a Jd. B around here that pulls 3000 pretty compitively, very rare he gets beat. Though sometimes he puts his 80 pound daughter on it to make weight. But it usually makes weight with 150 pound driver.
770
03-03-2004 07:24:36
My bro pulls his in the 3500 and 4000. He has pressed steel front and rear. No powertrol unit. Oh, He has no starter, battery or lights. His is a 1943.... Loose that weight and get down where you should be.....
jons
03-02-2004 20:55:40
my brother pulls a 51 jd b. he lightened up the front by taking off the roll-a-matic and put a front pedistial off a MT. he also has multiple weight brackets, so that you can move weight around depending apon track conditions. he has 13.6x38 firestones. just a few suggestions.
jon
red paint gotta pull
03-02-2004 18:01:20
Around here you see very few B's pulling. One thing is the weight but if you are spinning out then you probly need to add weight to rear of tractor and loose some up towards front. I had rather see front wheels in air a little and not spin
Shotgun
03-02-2004 18:54:30
 Re: Re: HELP WITH 1949 JOHN DEERE B PULLER in reply to red paint gotta pull, 03-02-2004 18:01:20
Round here you cant find a B that you can buy to pull
junkyard dog
03-03-2004 16:17:20
 Re: Re: Re: HELP WITH 1949 JOHN DEERE B PULLER in reply to Shotgun, 03-02-2004 18:54:30
get a farmall!
