1466 puller
BOB
03-03-2004 17:42:31
Hi i am wanting to build a illinois hot farm stock tractor cubic inch limit is 650 i was thinking of going with a 540 0r 570 what is the best way to build one like this .As for the ta what is the best there and clutch .
RPMs?
03-03-2004 20:25:36
 Re: 1466 puller in reply to BOB , 03-03-2004 17:42:31
What is the RPM limit?
Bob
03-03-2004 21:12:04
 Re: Re: 1466 puller in reply to RPMs?, 03-03-2004 20:25:36
YOU have to run factory style fuel injection pump and factory rpms
Bob
03-03-2004 21:14:40
 Re: Re: Re: 1466 puller in reply to Bob, 03-03-2004 21:12:04
How is the best way to get to the 540 and 570 cubic inch.
jason
03-03-2004 18:42:04
570ci block, Sigma "P" pump, HX 80 Holset charger, two disk clutch, and a Case IH Mechanical Diode TA. Bullet Proof setup that will win some pulls, if you can swing the $$$. Riverside and Hypermax engineering could fix you up too.
Reed
03-03-2004 19:36:15
 Re: Re: 1466 puller in reply to jason, 03-03-2004 18:42:04
Isn't an HX80 pretty big? I run an HT3B in a twin kit on my Dodge and that is near the size of an HX60. An 80 has to be huge. What's the CFM on that turbo? How many rpm's you gonna be turnin'?
jack
03-03-2004 19:19:18
o.k. stupid question what is a mechanical diode ta and were can I get one??? if it's what I think it is I will need one to. And is that what I ask for???
BigART
03-04-2004 15:30:59
 Re: Re: Re: 1466 puller in reply to jack, 03-03-2004 19:19:18
Pulloff.com has used parts to build 540, 570 and 600 cu ih's, additional pumps, 13 and 15 mm, ih pumps also recently listed. You'll need a vogal cam, or as suggested, riverside or hyper stuff, although I thought ihfs allowed a pumps, unless p standard. Ill 9000 lb farm stock allows 466 cubes and p-pumps, might(?) be a cheaper set up, and less maintainence. 28 or 29 hooks scheduled for 9000 fs this year.
