77 rods
Chads
03-04-2004 18:06:12
Does anyone know the specs of an Oliver 77 rod? center to center. Thanks! Chad
jpdunn
03-04-2004 20:33:51
 Re: 77 rods in reply to Chads, 03-04-2004 18:06:12
66 rods are 6.75. I'm sure 66 and 77 rods are the same. Have a set of tall 4.5 pistons fitted to these rods for off-set grinding an H if you're interested. Also have a good 26_ IH truck motor (I think it's the same as a 460 motor) with clutch and transmission, an M&W turbo kit, and an H parts tractor if you or somebody would want another H/460 project. I'd be interested in trading for JD parts, JD parts tractors, etc...
A.P.
03-05-2004 04:22:31
 Re: Re: 77 rods in reply to jpdunn, 03-04-2004 20:33:51
You are correct about the center to center dimension. The rods are the same from a 66 and 77. The Fleetline rods used a 2.0" rod journal. The Super's used a 2.25".
