Can't get reductoin gear cover off G!
Drew
11-15-2001 14:05:20
how do you get the cover off? I have the brake and the belt pully removed. the cover seams to be stuck on the bearing.
Mike S
11-16-2001 14:58:59
 Re: can't get reductoin gear cover off G! in reply to Drew, 11-15-2001 14:05:20
did you take the small two bolt cover off and remove the cotter pin and nut?
Drew
11-16-2001 15:36:25
 Re: Re: can't get reductoin gear cover off G! in reply to Mike S, 11-16-2001 14:58:59
I removed the small cover, cotter pin and nut befor I posted this. Thankx DREW
burns
11-15-2001 17:02:52
There is an indexing pin on the lower portion of the cover that can be a real bugger. Make sure that isn't causing some of your problem.
Drew
11-16-2001 15:40:57
 Re: Re: can't get reductoin gear cover off G! in reply to burns, 11-15-2001 17:02:52
The cover seems to be moving fine around the pins. It seems to be stuck around the bearing area. Do I need to remove the bearing first and if so how. The center of the bearing is smaller than the threads on the shaft.
Deere Jon 2000
11-18-2001 19:46:41
 Re: Re: Re: can't get reductoin gear cover off G! in reply to Drew, 11-16-2001 15:40:57
If I remember right, sometimes it worked to put a slight outward pressure on the cover with a small bar between the cover and the transmission case, or even through the clutch fork cover on the crankshaft drive gear and then rap on the end of the reduction gear shaft with a rubber mallet, dead-blow hammer or a hardwood block & hammer. Don't get too agressive with this, or you'll have bigger problems. Hope this helps.
