Enjoy pulling HEFTY tractors?
Mopower
03-09-2004 11:47:21
I was curious on getting some input from you guys that pull heavy classes like 7500 or 8500. I've always enjoyed watching the big JDs, Case's, G MM's, Olie99s, and Masseys grunt and lug. My GBD came new with 18.4x34 or 23.1x26 tires. I can bump up one size from stock according to local rules. What type and size of tires do you HEFTY TRACTOR guys like to use? What tractors do you pull?
Jim M
03-10-2004 09:33:50
 Re: Enjoy pulling HEFTY tractors? in reply to Mopower, 03-09-2004 11:47:21
I would run a good set of road worn tires that are already mentioned in 20.8 x 34 on 20" wide rims if they will allow them if not 18"
junkyard dog
03-09-2004 16:24:02
in our local deadwt pulls I have a bone stock SMTA that I pull in 11,500 class with firestone 16.9s . JD'Swith 18.4 tires can't touch me 720,730 820 ,830 MM'S irritates the $h!t out of the jd lovers especially when I tell em "it's only an M !"
Don c.
03-10-2004 18:03:04
 Re: Re: Enjoy pulling HEFTY tractors? in reply to junkyard dog, 03-09-2004 16:24:02
junk yard dog stock smta, ya right lol
Jack
03-09-2004 12:18:51
I had a set of 16.9X38 Firestone 23 degree Super All Traction that was a darn good biting tire on most tracks,I would like to find another set like them in a 15.5 or 14.9.
a puller
03-09-2004 12:09:20
we like to run firestone 18.4 38 field and road tires, or run the BF Goodrich tires that are the similar pattern, although WE don't run them cause we aint found any, I do have a cousin that does, and he competes good with a 4020 in the 9000 with 20.8x38 tires. The armstrong/titan tires I have heard alot of good about, but haven't tried them. I havent' tried the tires yet, but eh 23 degree or whatever firestone tires that are new look like they would do good, will try a set sometime soon...
ChadS
03-09-2004 17:27:27
 Re: Re: Enjoy pulling HEFTY tractors? in reply to a puller, 03-09-2004 12:09:20
I pull a JD 730 gas in deadweight. I weigh it in at 9500, and up, 15.5X38 duals, Nice combo for dead weight pulling. I run 2-3 gear most of the time. Chad
