10000lb pullers
Jack
03-10-2004 10:28:04
Were tryin to get a 10000 non turbo class together for our May pull and I wanted to ask a question.If we had a 6mph speed limit non turbo,which would be the favorite machine for the job,IH,Oliver,JD,or something else?There is supposed to be a 966 to show up along with a 930 Case.I pull 5500 up to 7500lb so I don't know much about the bigger tractors.Thanks
Dave
03-12-2004 08:51:38
 Re: 10000lb pullers in reply to Jack, 03-10-2004 10:28:04
What about a Oliver 2255 with a 3208 Cat.
650 cid, 3500 RPM, 18.4 x 38 Radials.
Would it fit in the rules?
JD 40203020
03-11-2004 14:31:54
JD 4020, 4000, or 4040 will do good. Also MM 1050 or 1000(I think thats the model numbers) will usually win. Also some fords like the TW10 or TW15, or something from the 7000 or 8000 series will do well also. With the speed limits i think the IH won't do so well!
Jeff
03-11-2004 07:14:57
Hey jack, I heard last night that the Rae's are thinking of bringing a 966 also. We need to find someone with something like a 4020 or something to get in it also for a good brand competition.
Mopower
03-11-2004 06:43:02
Big MM like GB or GVI would do nicely. A few of the big Case machines could take it but I don't know as much about those. Massey 97 or 99. Oliver 99, 99Super, 990, etc.
joecool
03-10-2004 17:28:59
where is this pull? A friend has a case 600 that may be able to make it
Jack
03-11-2004 03:46:35
 Re: Re: 10000lb pullers in reply to joecool, 03-10-2004 17:28:59
Dresden TN,May 3rd.6250 5mph class also that pays good to the winner also.Come on down.
Krouthead
03-12-2004 17:09:32
 Re: Re: Re: 10000lb pullers in reply to Jack, 03-11-2004 03:46:35
How about a good ole kroutburner? She holds her own with the afore mentioned. Is this antique,classic or pull what you bring? Non turbo right?
Krout
Jim M
03-10-2004 18:51:01
John: My dad and I came across some Case wheel weights. We got more than we need if you know of anyone wantings some. Also have some for the standard tractors also. $50 each.
