Lp heads/manifolds vs gas counterparts
shannon
11-19-2001 09:26:09
do the lp heads flow any better than the gas heads, or do they just have the smaller combustion chamber as the only difference? same question for the manifolds too. thanks
answer
11-19-2001 10:03:37
 Re: lp heads/manifolds vs gas counterparts in reply to shannon, 11-19-2001 09:26:09
LP cylinder heads would have basically the same flow with smaller combustion chambers as you mentioned. The manifolds are generally different. The gasoline or all fuel counterparts are designed with a "heater" area in them that the LP manifolds do not have. This would loose hp with LP while it vaporizes, makes burnable, the gasoline and more so kerosene.
