HARDENED VALVES SEATS
DON C
03-17-2004 11:41:53
I'M HAVE THE HEAD MILLED ON MY FARMALL H AND WHILE ITS OUT THEY ARE DOING SOME PORTING AND POLISHING SHOULD I HAVE THEM INSTALL HARDENED VALVE SEATS OR IS IT A WASTE OF MONEY THANKS DON
dan
03-17-2004 20:04:26
 Re: HARDENED VALVES SEATS in reply to DON C , 03-17-2004 11:41:53
with todays fuels with no real lead, i won,t do a valve job for my self or a customer with out hard seats in the exhaust. if it's off and at the shop the only added expense is the seats and machine work to install them. at our shop that would be about $55.00 for a 4 cylinder.
farmall
03-17-2004 13:36:30
Milling your head, other than truing, is a wast of a good head. The seats only need to be replaced if worn to much. Hope this helps, Farmall
junkyard dog
03-17-2004 12:19:42
hey don: just what are you up to? trying to catch the pup? coming to duksa's pull in apr? see you soon.JYD
